Protect pyboard from reading the code
Is it possible to protect python code from being read via USB or any other way?
Re: Protect pyboard from reading the code
If you ship the python modules already compiled, then people won' t be able to access the source.
A Micropython decompiler is probably feasible.
In general, you should not waste time trying to prevent reverse engineering, although it depends what the exact application is (and hence motivation).
In order to do this you should read up on "read protection" in the datasheet.
If the device is not read-protected, then its trivial to read the entire contents of flash using DFU. With read-protection enabled, you can't.
Disabling read-protection does a complete erase of flash.
Thanks, that's what I'm looking for )dhylands wrote:In order to do this you should read up on "read protection" in the datasheet.
in case of someone is interested in such protection: https://github.com/xyb/upy-stm-flash/blob/master/rdp.py
The only question I have - if I will set Level 2 - will micropython and my code work on such system?
If you choose to use level 2 then DFU and JTAG are both disabled, which means that your code will need to provide a mechanism to reflash should you ever wish to change the onboard firmware for any reason.
