It doesn't respond to an I2C scan. I then connected the Pyboard to a known good I2C module using the same Pyboard pins and code; it responded correctly.
I've tried running with CS open circuit, connected to Gnd and connected to 3v3: each time it displays an empty list. Does anyone have any ideas before I start fiddling around with an Arduino to decide if it needs sending back? This is the code I'm using for the scan, with very conservative timings for the reset.
import utime
import ssd1306
pscl = machine.Pin('Y9', machine.Pin.OUT_PP)
psda = machine.Pin('Y10', machine.Pin.OUT_PP)
rst = machine.Pin('Y11', machine.Pin.OUT_PP)
rst(1)
utime.sleep_ms(100)
rst(0)
utime.sleep_ms(100)
rst(1)
utime.sleep_ms(1000)
i2c = machine.I2C(scl=pscl, sda=psda)
print(i2c.scan())
