I2C EEPROM Memory Read Problem [SOLVED]
GeekCharge
Postby GeekCharge » Wed Jan 11, 2017 9:55 am
I have an I2C eeprom connected to the pyboard v1.1 and I am having issues with reading the memory. Device comes up fine during scan, and I can read from it using mem_read method. However, it seems I can only read once, i.e. if I read let's say 10 bytes from start address 0 I will get some data that I know it's there, but if I execute any further reads from that point onward I only get 0xFF regardless of how much data I read. This will persist until I restart the whole setup. Any ideas?
Many thanks,
Geek
GeekCharge
Re: I2C EEPROM Memory Read Problem
Postby GeekCharge » Wed Jan 11, 2017 11:49 am
Solved! When reading the docs I was using old version prior to 16bit addressing being introduced. Now I can read the memory without issues.
mcauser
Re: I2C EEPROM Memory Read Problem [SOLVED]
Postby mcauser » Fri Feb 03, 2017 2:19 pm
Same problem fixed over in ESP8266: viewtopic.php?f=16&t=2874
Return to “The MicroPython pyboard”
Who is online
Users browsing this forum: Google Feedfetcher and 2 guests
