Adding a BOOT0 switch
Post by dhylands » Wed May 07, 2014 6:15 am
Since I flash new versions of MicroPython quite frequently, I decided to add a BOOT0 switch.
The pyboard is mounted in a SliceCase
The red wire runs to 3.3v and the white wire runs to the pull-down resistor on BOOT0. A dab of hot glue holds the switch in place on the processor.
Now I can enter DFU mode by pressing BOOT0 and RESET.
pfalcon
Re: Adding a BOOT0 switch
Post by pfalcon » Wed May 07, 2014 11:26 am
Good use for MCU - now it doesn't take so much space uselessly ;-)
Awesome MicroPython list
mbirth
Post by mbirth » Mon Oct 20, 2014 1:55 pm
Do you only have to short BOOT0 and 3V3 during reset, or does it have to be permanently shorted during the whole flashing process?
pyBoard v1.0 + LCD32MKv1.0 | WiPy + Expansion Board | GitHub
Post by dhylands » Mon Oct 20, 2014 6:30 pm
The BOOT0 switch only needs to be held while the board resets. You can release it a split second after releasing the reset button.
The red/yellow/blue LEDs turn on dimly, which is your indication that you're in DFU mode.
Incidently, with the new firmware, you can use:
pyb.bootloader()
to enter into DFU mode, so the only time I need to use the BOOT0 switch now is when I totally bork the board.
mbirth
Post by mbirth » Mon Oct 20, 2014 6:34 pm
Awesome! Thank you!
