mu editor for micropython
Re: mu editor for micropython
Fork now supports pasting at the REPL (ctrl-V). So ctrl-E ctrl-V ctrl-D allows code to be pasted in from the editor window or from another application.
poul@poul-S400CA ~/Programmer/mu/mu $ ./run.py
File "./run.py", line 2, in <module>
from mu.app import run
File "/home/poul/Programmer/mu/mu/mu/app.py", line 27, in <module>
from mu.logic import Editor, LOG_FILE, LOG_DIR
File "/home/poul/Programmer/mu/mu/mu/logic.py", line 32, in <module>
from pycodestyle import StyleGuide, Checker
ImportError: No module named 'pycodestyle'
poul@poul-S400CA ~/Programmer/mu/mu $ pycodestyle --version
2.0.0
What I lack, one symlink or?
Yes Frida is my watchdog!
Try
You may also need
These are handy features for checking Python code for style and correctness.
$ pip install pycodestyle
$ apt-get install pyflakes
[quote="pythoncoder"]Fork now supports pasting at the REPL (ctrl-V). So ctrl-E ctrl-V ctrl-D allows code to be pasted in from the editor window or from another application.[/quote]
Hello to everyone!
I'm new to microPython and my knowledge is mostly Python 2.7 (hobbyist level, I wrote some small utility in order to make my work easy, but nothing too fancy).
I wanted to try MU but seems that I got something missing (Python 3.5.2 and Windows). I don't understand what I'm missing:
File "C:\Users\itafiu21\Desktop\mu-master\mu\app.py", line 27, in <module>
File "C:\Users\itafiu21\Desktop\mu-master\mu\logic.py", line 33, in <module>
from mu.contrib import uflash, appdirs, microfs
File "C:\Users\itafiu21\Desktop\mu-master\mu\contrib\microfs.py", line 20, in <module>
from serial.tools.list_ports import comports as list_serial_ports
ImportError: No module named 'serial'
(sorry for the unformatted error, I could not get the code tag to work).
Can anyone tell me what I'm missing here?
Many thanks!
Hello to everyone!
Many thanks!
The following dependencies need to be installed, in addition to the ones I mentioned above (pycodestyle and pyflakes):
python3-pyqt5
python3-serial
Hopefully someone with Windows knowledge will be able to tell you how to do this.
python3-pyqt5
python3-serial
[quote="pythoncoder"]The following dependencies need to be installed, in addition to the ones I mentioned above (pycodestyle and pyflakes):
python3-pyqt5
python3-serial
Hopefully someone with Windows knowledge will be able to tell you how to do this.[/quote]
I got it to work with pyserial, unfortunately it crashes very often.
Tomorrowland I Will try it on macosx.
Thanks a anyway for the help!
python3-pyqt5
python3-serial
Well it's standard Python: if it crashes on Windows you could always fix it Does it produce an error report?
I assume you're using my fork? As described above @askvictor's version (and the original) gave the appearance of a hang because the dialog boxes were not properly defined as modal dialogs. The change has been accepted upstream but I don't know if @askvictor is still supporting his fork.
For what it's worth I've used my fork extensively under Linux and it's reliable.
[quote="pythoncoder"]For what it's worth I've used my fork extensively under Linux and it's reliable.[/quote]
Unfortunately it still says :
[code]Traceback (most recent call last):
File "/home/mofitz/Downloads/mu-master/mu/app.py", line 27, in <module>
File "/home/mofitz/Downloads/mu-master/mu/logic.py", line 30, in <module>
from PyQt5.QtSerialPort import QSerialPortInfo
ImportError: No module named 'PyQt5.QtSerialPort'[/code]
although I'm on a linux-machine and installed all of the dependencies you mentioned.
Any hints?
Any hints?
It's easy to install the dependencies for the wrong version of python.
For example, under ubuntu, you may have pip, pip2, and/or pip3 depending on which version of ubuntu you're running.
So if you're running python3 you need to make sure that the dependencies are installed for python 3 and not python 2 (and vice-versa).
A few fixes pushed
