I am having problem with webrepl_setup command. From the reference document I read that we have to enable it but whenever I write webrepl_setup command it shows the following error -:
File "webrepl_setup.py", line 111, in <module>
File "webrepl_setup.py", line 80, in main
File "webrepl_setup.py", line 49, in get_daemon_status
I am using an Esp8266 01 with 1MB flash and flashed my module properly without any errors with the latest sdk.
Moreover , I don't know whether it is related to it or not but when I type os.listdir() I get a lot of garbage something like ['\x00\x00\x00\x00\x00\x00\x00\x00.\x00\x00\x00'].
I tried using previous builds but no use. I don't know what have I done wrong.
webrepl_setup error
Re: webrepl_setup error
This is related. Please erase_flash before flashing your micropython firmware -- that should help.
