How to read Map() function in micropython?
I'm new to micropython.
How to write Map() function in micropython?
In arduino C:
int mappedValue;
int moistureValue = analogRead(A0);
mappedValue = map(moistureValue,AirValue,WaterValue, 0, 100);
How toconvert it into micropython?
How to use the library? I use Thonny but where I can see the examples Arduino ide?
In arduino C:
int mappedValue;
Re: How to read Map() function in micropython?
It's really just simple math.
You will NEED to verify that (loval < hival) and that (tolow < tohigh)
and return the result in the form you want (int vs float).
A Celsius to Fahrenheit conversion would be as follows:
>>> map(37, 0, 100, 32, 212)
98.6
def map(val, loval, hival, tolow, tohigh):
if loval <= val <= hival:
return (val - loval)/(hival-loval)*(tohigh-tolow) + tolow
raise(ValueError)
98.6
For a simple proportional mapping a single function as given by 'fe203' will suffice.
This is my generic mapping solution ... https://www.raspberrypi.org/forums/view ... 3#p1866943
That handles multiple mappings depending on input value.
Bear in mind that map is a Python keyword (with different functionality).
It's actually a built-in function (or rather a class acting like a function), which means you can use "map" for identifiers without getting a syntax error. You will then of course shadow the builtin function.
Indeed, it will work. But in my opinion it is not pretty and may confuse anyone reading the code.
I'd probably just rename map() to rescale(). The map(), as described
by the op, reminds me of the map function from Parallax BASIC for
their Stamp controllers.
-Rusty-
-Rusty-
we already did this last year: map function
for floats, a modification of the old code from Processing that Wiring/Arduino inherited will do:
For this reason, Arduino also provides the constrain() function if you want to keep the output range constrained
def valmap(value, istart, istop, ostart, ostop):
return ostart + (ostop - ostart) * ((value - istart) / (istop - istart))
Not if you're extrapolating, which is often more useful than stopping with an exception.
- OlivierLenoir
You can also read this.
Olivier Lenoir
https://gitlab.com/olivierlenoir
This is very helpful, thanks a lot!
