Hi all,
Since 3 days I try to select the right sentence ( $GPRMC ) from an GPS via the uart.
When I use the readline(), no problems all the sentences are read one by one, except that when I print them there is a "b" as the first character of the line.
When I try to identify the good sentence by:
cad=uart.readline(7) #just read the first 7 characters of the sentence
if (cad == '$GPRMC,'): # compare these 7 characters to $GPRMC,
data=uart.readline() #read the rest of the line for parsing it later
That don't work!
Is there a way for not having the "b" in front of the extracted line ?
See somewhere that tha "b" is displaying by micropython to say that's a binary result.
If someone can help me ?
Best regards
Jiemde
Parsing GPS sentence
Re: Parsing GPS sentence
You need to understand the difference between unicode strings and binary strings. Strings with a b prefix are binary strings, and strings without a b prefix are unicode strings.
Reading from a uart returns a binary string, so you should either compare it with a binary string or convert it to a unicode string in order to compare it:
So you should change your comparison from: to be instead.
>>> 'abc' == b'abc'
False
>>> 'abc' == b'abc'.decode('utf-8')
True
if (cad == b'$GPRMC,'):
I think you need to read up on Python3 and Unicode. The preceding b denotes a bytes object which is a sequence of 8 bit quantities. In Python3 this is not the same as a string, which is a sequence of Unicode characters. To perform a comparison the types must match. To convert from a string to bytes, do the following:
As you might guess, the reverse operation can be performed with a matching encode() function.
>>> s = 'Rats. And more rats.'
>>> s
>>> s.encode('UTF-8')
b'Rats. And more rats.'
Thanks!
When trying the news comparison in the Micropython console of Pymakr, that's work fine, but not yet in the main.py ?
But today I'm tired an try again tomorrow morning !
Regards
Jiemde
Regards
Jiemde
@jiemde The documentation for UART.readline() method http://docs.micropython.org/en/latest/w ... T.readline makes no mention of an argument. Are you sure
actually works? I'd have written
and then used
to extract the first 7 characters.
cad = uart.readline()
cad[0:7]
Hi Pythoncoder,
it's work!, you get the same answer, but in one line instead of 2.
And when you use the uart.readline() again, you get the rest of the line.
regards
Jiemde
regards
Jiemde
