wondering if somebody already has written a routine for wipy to work with a rotary encoder
and likes to share it
![Wink ;)](./images/smilies/icon_e_wink.gif)
# -*- coding: utf-8 -*-
"""MicroPython rotary encoder library."""
ENC_STATES = (0, -1, 1, 0, 1, 0, 0, -1, -1, 0, 0, 1, 0, 1, -1, 0)
class Encoder(object):
def __init__(self, pin_x = 'GP4',pin_y = 'GP5', pin_mode=Pin.PULL_UP,
scale=1,min=0, max=100, reverse=False):
self.pin_x = (pin_x if isinstance(pin_x, Pin) else
Pin(pin_x, mode = Pin.IN, pull = pin_mode))
self.pin_y = (pin_y if isinstance(pin_y, Pin) else
Pin(pin_y, mode = Pin.IN, pull = pin_mode))
self.pin_mode = pin_mode
self.scale = scale
self.min = min
self.max = max
self.reverse = 1 if reverse else -1
# The following variables are assigned to in the interrupt callback,
# so we have to allocate them here.
self._pos = -1
self._readings = 0
self._state = 0
self.set_callbacks(self._callback)
def _callback(self, line):
self._readings = (self._readings << 2 | self.pin_x.value() << 1 |
self.pin_y.value()) & 0x0f
self._state = ENC_STATES[self._readings] * self.reverse
if self._state:
self._pos = min(max(self.min, self._pos + self._state), self.max)
def set_callbacks(self, callback=None):
self.irq_x = self.pin_x.irq(trigger = Pin.IRQ_FALLING | Pin.IRQ_RISING, handler = callback)
self.irq_y = self.pin_y.irq(trigger = Pin.IRQ_FALLING | Pin.IRQ_RISING, handler = callback)
@property
def position(self):
return self._pos * self.scale
def reset(self):
self._pos = 0
This is an example of why post editing is to be prohibited in some cases. After you altering your typo in the initial post, Pythoncoders response seems to be stupid. Please at least comment your edit accordingly!nui_de wrote:![]()
yep - thank you, I have read the manual but missed that statement and of course its "RISING"
Looked fine to me as I wrote it down and I got no Error with "RAISING".
