WiPy dead after connecting SafeBoot pin with VIN
Re: WiPy dead after connecting SafeBoot pin with VIN
apologies newbie excuse
I think the docs still need some cleaning up. For instance the math module is available from the module index and the a-z page: http://micropython.org/resources/docs/e ... odule-math and sys.platform should be "WiPy".danicampora wrote:That only works in the pyboard, not in the WiPy. Make sure to be browsing the WiPy docs:pyboard.bootloader()
http://micropython.org/resources/docs/e ... index.html
And not the ones from the pyboard.
Andrew
- danicampora
Yes that's correct, thanks for the feedback. The multiboard support on the docs still needs a bit of tweaking.I think the docs still need some cleaning up. For instance the math module is available from the module index and the a-z page: http://micropython.org/resources/docs/e ... odule-math and sys.platform should be "WiPy".
I did exactly the same....
Now the WiPy is booting from factory firmware all the time.
Is there any chance to change the SafeBoot pin?
I tried pulling it down to ground with a wire to the ground pin but that didn't work for me - it's worth trying though. Otherwise as I say mine starting working again on its own after a few days. Very mysterious.Sebastian wrote:I did exactly the same....
Andrew
I tried the same but only factory firmware is booting at the moment.
The rest seems to work normal. I can execute files and WLAN is working but i'm not sure why the Blynk samples are not working.
Now i have to wait for my ordered replacement wipys.
- danicampora
Blynk examples require the latest firmware.
