SyntaxError: decimal numbers not supported
Re: SyntaxError: decimal numbers not supported
Post by pythoncoder » Mon Mar 07, 2016 7:10 am
@danicampora It would be good to have a definitive answer on this one. Will the WiPy ever be capable of supporting basic float arithmetic? I don't mind waiting as long as it takes while you figure it out, but it would be good to know if it's a problem waiting to be fixed or something which is simply not practicable.
My personal view is that if you can't write a = b/c it isn't Python.
jobbyworld
Post by jobbyworld » Sat Mar 12, 2016 10:53 pm
Should be great to have floating point enable for testing.
I have a pyb and wipy,
wifi apmode is great
sleep mode is cool
But without floating point, can't compute altitude with barometric and temperature,
Can't compute gps data...
So i'm using pyboard until i receive my lopy :-)
Thanks to all micropython, creator and contributor.
danicampora
Post by danicampora » Sun Mar 13, 2016 10:43 am
Hi guys,
I am sorry to say that floating point is not coming to the WiPy, it takes too much space leaving very little ram available.
Cheers,
Daniel
photoacoustic
Post by photoacoustic » Sun Mar 13, 2016 6:46 pm
@danicampora
This is really a bad new!
How to teach micrpython and say hey don't use a/b ...?
Very bad new!
I hope Lopy will not have the same story!
Best regards
danicampora
Post by danicampora » Sun Mar 13, 2016 6:48 pm
You can use a//b to make it a floor divide.
Cheers,
Daniel
photoacoustic
Post by photoacoustic » Sun Mar 13, 2016 6:54 pm
Yes.
I will try.
Some examples of usage are welcome. On Pycom it seems that some examples are coming..
marfis
Post by marfis » Wed Mar 16, 2016 2:30 pm
@jobbyworld: Most likely you can use your sensors with fixed point, see for example
https://github.com/micropython/Micropython/pull/1843 and other drivers which implement both fixed point and floating point support. Most of the time the only difference is one line of code.
In the link above was also a question of Damien if it made sense to support fixed point support for sensors.
It would be good if this can be clarified in the future, especially if more sensors drivers should find their way to the main repo.
jgmdavies
Post by jgmdavies » Fri Aug 26, 2016 3:24 pm
I've written a simple WiPy float package if anyone wants to try it out - please see http://forum.micropython.org/viewtopic. ... 205#p13205
It doesn't have the syntactic nicety of x = y / z, but you can achieve something similar, e.g.
x = Float(1)
y = Float(3)
z = Float.divide(x, y)
print(x)
Jim
jgmdavies
Post by jgmdavies » Sat Aug 27, 2016 10:39 am
I've added more operator overloads to WiPyFloat (see above), so that this sort of thing now works:
x = Float(1) / Float(3)
print(x)
x = Float("1.45") / Float("3.78")
print(x)
It's just under 6 Kb at the moment, as measured by gc.mem_free().
Jim
WiPyFloat.py
# WiPyFloat.py
# Last modified: 27 Aug 2016
# J.G.Davies, Jacobus Systems Ltd., Brighton & Hove, UK.
# This code is hereby released as Public Domain.  I would appreciate an acknowledgement if you find it useful.
class Float():
    mantissa = 0
    exponent = 0
    def __init__(self, f=None):
        if f:
            if (type(f).__name__ == "Float"):
                self.mantissa = f.mantissa
                self.exponent = f.exponent
            elif (type(f).__name__ == "int"):
                self.mantissa = int(f)
                self.exponent = 0
            elif (type(f).__name__ == "str"):
                self.load(str(f))
            self.normalise()
        return
    # Operator overloads.
    def __abs__(self):
        result = Float(self)
        result.mantissa = abs(result.mantissa)
        return result
    def __add__(self, other):
        return Float.add(self, other)
    def __eq__(self, other):
        self.normalise()
        other.normalise()
        return (self.mantissa == other.mantissa) and (self.exponent == other.exponent)
    def __mul__(self, other):
        return Float.multiply(self, other)
    def __neg__(self):
        result.mantissa = -result.mantissa
        return result
    def __pos__(self):
        return Float(self)
    def __str__(self):
        return self.str()
    def __sub__(self, other):
        return Float.subtract(self, other)
    def __truediv__(self, other):
        return Float.divide(self, other)
    # Static methods.
    @staticmethod
    def add(f1, f2):
        # Return a new Float holding (f1 + f2).
        result = Float(f1)
        result.add_float(f2)
        return result
    @staticmethod
    def divide(f1, f2):
        # Return a new Float holding (f1 / f2).
        result = Float(f1)
        result.divide_float(f2)
        return result
    @staticmethod
    def multiply(f1, f2):
        # Return a new Float holding (f1 * f2).
        result = Float(f1)
        result.multiply_float(f2)
        return result
    @staticmethod
    def subtract(f1, f2):
        # Return a new Float holding (f1 - f2).
        result = Float(f1)
        result.subtract_float(f2)
        return result
    # Methods.
    def add_float(self, f, add=True):
        # Add Float 'f' to this Float.
        # Align the exponents.
        self_mantissa = self.mantissa
        self_exponent = self.exponent
        f_mantissa = f.mantissa
        f_exponent = f.exponent
        if (f_exponent < self_exponent):
            shift = self_exponent - f_exponent
            self_mantissa *= 10 ** shift
            self_exponent -= shift
        elif (f_exponent > self_exponent):
            shift = f_exponent - self_exponent
            f_exponent -= shift
        if add:
            self.mantissa = self_mantissa + f_mantissa
            self.mantissa = self_mantissa - f_mantissa
        self.exponent = self_exponent
        self.normalise()
        return self
    def debug(self):
        s = "Float: {0}, {1}".format(self.mantissa, self.exponent)
        return s
    def divide_float(self, f):
        # Divide this Float by 'f'.
        self.mantissa *= 100000000
        self.exponent -= 8
        self.mantissa //= f.mantissa
        self.exponent -= f.exponent
        self.normalise()
        return self
    def int(self):
        result = 0
        return result
    def load(self, s):
        s = s.strip().lower()
        pos = True
        if (s[0] == "+"):
            s = s[1:]
        elif (s[0] == "-"):
            s = s[1:]
            pos = False
        if "e" in s:
            return self.load_scientific(s, pos)
        if "." in s:
            whole, decimal = s.split(".")
            if not decimal:
                # There is no decimal part.
                # TODO: if 'whole' ends in zeros, could scale the number and set self.exponent.
                # This would help keep 'mantissa' a simple 31-bit int on the WiPy.
                self.mantissa = int(whole)
                if not pos: self.mantissa = -self.mantissa
                self.exponent = 0
                self.normalise()
                return True
            # There is a decimal part.
            if whole and (int(whole) == 0):
                whole = None
            if not whole:
                # There is no whole part.
                value, nleading = self.parse_decimal(decimal)
                self.mantissa = int(value)
                self.exponent = -nleading - len(value)
                self.normalise()
                return True
            # There is a whole part and a decimal part.
            whole = whole.lstrip("0")
            decimal = decimal.rstrip('0')
            self.mantissa = int(whole + decimal)
            self.exponent = -len(str(decimal))
            self.normalise()
            self.mantissa = int(s)
            self.exponent = 0
            self.normalise()
            return True
        return True
    def multiply_float(self, f):
        # Multiply this Float by 'f'.
        self.mantissa *= f.mantissa
        self.exponent += f.exponent
        self.normalise()
        return self
    def normalise(self):
        # Normalise where possible.
        if (self.mantissa != 0):
            s = str(self.mantissa)
            stripped = s.rstrip("0")
            diff = len(s) - len(stripped)
            if (diff > 0):
                self.mantissa = int(stripped)
                self.exponent += diff
        return True
    def str(self, format="F"):
        if ("E" in format):
            return self.str_scientific()
        # Use format "F".
        pos = (self.mantissa >= 0)
        result = str(abs(self.mantissa))
        if (self.exponent > 0):
            result += "0" * self.exponent
        elif (self.exponent < 0):
            if (-self.exponent < len(result)):
                cut = len(result) + self.exponent
                result = result[:cut] + "." + result[cut:]
                n_zeros = -self.exponent - len(result)
                result = "0." + ("0" * n_zeros) + result
        if not pos: result = "-" + result
        return result
    def subtract_float(self, f):
        # Subtract Float 'f' from this Float.
        return self.add_float(f, False)
    # Helper methods.
    def load_scientific(self, s, pos):
        mant, exp = s.split("e")
        self.load(mant)
        self.exponent += int(exp)
        self.normalise()
        return False
    def parse_decimal(self, s):
        nleading = 0
        for c in s:
            if (c != "0"): break
            nleading += 1
        if (nleading == 0):
            value = s
            value = s[nleading:]
        return value, nleading
    def str_scientific(self):
        len_mantissa = len(result)
        if (len(result) > 1):
            result = result[:1] + "." + result[1:]
            result = result.rstrip("0")
            result = result.rstrip(".")
        result += "e" + str(self.exponent + len_mantissa - 1)
        return result
#import Float_tests
Float_tests.py
# Float_tests.py
from WiPyFloat import Float
def test1():
    # 'load' and 'str' methods.
    print("test1 - load / str")
    f1 = Float()
    f1.load("1.3")
    print(PassFail(f1.str() == "1.3"), "1.3 ->", f1, f1.str("E"))
    f1.load("-1.3")
    print(PassFail(f1.str() == "-1.3"), "-1.3 ->", f1, f1.str("E"))
    f1.load("2000.05")
    print(PassFail(f1.str() == "2000.05"), "2000.05 ->", f1, f1.str("E"))
    f1.load("0.01")
    print(PassFail(f1.str() == "0.01"), "0.01 ->", f1, f1.str("E"))
    f1.load("0.0123")
    print(PassFail(f1.str() == "0.0123"), "0.0123 ->", f1, f1.str("E"))
    f1.load("0.00123")
    print(PassFail(f1.str() == "0.00123"), "0.00123 ->", f1, f1.str("E"))
    f1.load("1.23e-3")
    print(PassFail(f1.str() == "0.00123"), "1.23e-3 ->", f1, f1.str("E"))
    f1.load("1.23e6")
    print(PassFail(f1.str() == "1230000"), "1.23e6 ->", f1, f1.str("E"))
    f1.load("5e6")
    print(PassFail(f1.str() == "5000000"), "5e6 ->", f1, f1.str("E"))
    print("")
    return True
def test2():
    # Addition.
    print("test2 - Addition")
    f1 = Float()
    f2 = Float()
    f1.load("2000.05")
    f2.load("0.001")
    f3 = Float.add(f1, f2)
    print(PassFail(f3.str() == "2000.051"), f1, "+", f2, "->", f3, f3.str("E"))
    f1.load("0.1")
    f2.load("0.2")
    print(PassFail(f3.str() == "0.3"), f1, "+", f2, "->", f3, f3.str("E"))
    f1.load("500")
    f2.load("600")
    print(PassFail(f3.str() == "1100"), f1, "+", f2, "->", f3, f3.str("E"))
    f1.load("500")
    f2.load("-600")
    print(PassFail(f3.str() == "-100"), f1, "+", f2, "->", f3, f3.str("E"))
    f1.load("-500")
    f2.load("600")
    print(PassFail(f3.str() == "100"), f1, "+", f2, "->", f3, f3.str("E"))
    print("")
    return True
def test3():
    # Subtraction.
    print("test3 - Subtraction")
    f1 = Float()
    f2 = Float()
    f1.load("2000.05")
    f2.load("0.001")
    f3 = Float.subtract(f1, f2)
    print(PassFail(f3.str() == "2000.049"), f1, "-", f2, "->", f3, f3.str("E"))
    f1.load("0.1")
    f2.load("0.2")
    print(PassFail(f3.str() == "-0.1"), f1, "-", f2, "->", f3, f3.str("E"))
    f1.load("10")
    f2.load("0.6667")
    print(PassFail(f3.str() == "9.3333"), f1, "-", f2, "->", f3, f3.str("E"))
    f1.load("500")
    f2.load("600")
    print(PassFail(f3.str() == "-100"), f1, "-", f2, "->", f3, f3.str("E"))
    f1.load("500")
    f2.load("-600")
    print(PassFail(f3.str() == "1100"), f1, "-", f2, "->", f3, f3.str("E"))
    f1.load("-500")
    f2.load("600")
    print(PassFail(f3.str() == "-1100"), f1, "-", f2, "->", f3, f3.str("E"))
    print("")
    return True
def test4():
    # Multiplication.
    print("test4 - Multiplication")
    f1 = Float()
    f2 = Float()
    f1.load("5")
    f2.load("6")
    f3 = Float.multiply(f1, f2)
    print(PassFail(f3.str() == "30"), f1, "*", f2, "->", f3, f3.str("E"))
    f1.load("500")
    f2.load("600")
    print(PassFail(f3.str() == "300000"), f1, "*", f2, "->", f3, f3.str("E"))
    f1.load("5e3")
    f2.load("6e3")
    print(PassFail(f3.str() == "30000000"), f1, "*", f2, "->", f3, f3.str("E"))
    f1.load("5e6")
    f2.load("6e6")
    print(PassFail(f3.str() == "30000000000000"), f1, "*", f2, "->", f3, f3.str("E"))
    print("")
    return True
def test5():
    # Division.
    print("test5 - Division")
    f1 = Float()
    f2 = Float()
    f1.load("1")
    f2.load("3")
    f3 = Float.divide(f1, f2)
    print(PassFail(f3.str()[:7] == "0.33333"), f1, "/", f2, "->", f3, f3.str("E"), f3.debug())
    f1.load("5")
    f2.load("6")
    print(PassFail(f3.str()[:7] == "0.83333"), f1, "/", f2, "->", f3, f3.str("E"), f3.debug())
    f1.load("500")
    f2.load("600")
    f1.load("5e3")
    f2.load("6e3")
    f1.load("5e6")
    f2.load("6e6")
    print("")
    return True
def test6():
    # Object creation options.
    print("test6 - Object creation")
    f1 = Float()
    print(PassFail(f1.str() == "0"), f1, f1.debug())
    f1 = Float(123)
    print(PassFail(f1.str() == "123"), f1, f1.debug())
    f1 = Float("3.1416")
    print(PassFail(f1.str() == "3.1416"), f1, f1.debug())
    f2 = Float(f1)
    print(PassFail(f1.str() == "3.1416"), f2, f2.debug())
    print("")
    return True
def test7():
    # Equality / Inequality operator overloads.
    print("test7 - Equality / Inequality operator overloads")
    f1 = Float(123)
    f2 = Float("123")
    f3 = Float("123.0001")
    print(PassFail(f1 == f2), "(", f1, "==", f2, ") is", f1 == f2)
    print(PassFail(f1 != f3), "(", f1, "==", f3, ") is", f1 == f3)
    print(PassFail(f1 == f2), "(", f1, "!=", f2, ") is", f1 != f2)
    print(PassFail(f1 != f3), "(", f1, "!=", f3, ") is", f1 != f3)
    print("")
    return True
def test8():
    # test8 - Arithmetic operator overloads.
    print("test8 - Arithmetic operator overloads")
    f1 = Float("1.8")
    f2 = Float("3.7")
    f3 = f1 + f2
    print(PassFail(f3.str() == "5.5"), f1, "+", f2, "->", f3, f3.str("E"))
    f3 = f1 - f2
    print(PassFail(f3.str() == "-1.9"), f1, "-", f2, "->", f3, f3.str("E"))
    f3 = f1 * f2
    print(PassFail(f3.str() == "6.66"), f1, "*", f2, "->", f3, f3.str("E"))
    f3 = f1 / f2
    print(PassFail(f3.str()[:8] == "0.486486"), f1, "/", f2, "->", f3, f3.str("E"))
    return True
def PassFail(cond):
    return ("PASS" if cond else "FAIL") + ": "
test1()
test2()
test3()
test4()
test5()
test6()
test7()
test8()
MiPy
Post by MiPy » Sat Aug 27, 2016 10:52 am
Looks nice! I'm going to try it out in a couple of days.
