Telnet "connection closed by foreign host"
Post by pythoncoder » Sat Oct 17, 2015 11:50 am
I'm getting this if I leave the WiPy at the REPL for any length of time. The WiPy is in the same room as the AP, 2-3 metres away. There are two other Linux systems using the AP, but both were idle while I was testing. Is there a timeout on the REPL standing idle?
andrew
Re: Telnet "connection closed by foreign host"
Post by andrew » Sat Oct 17, 2015 12:02 pm
Is it after 5 minutes? That's what I'm seeing.
Andrew
danicampora
Post by danicampora » Sat Oct 17, 2015 12:05 pm
Hi Peter,
Yes there's a 5 minute timeout by default (to prevent half closed sockets). You can increase this timeout easily:
network.server_timeout(time_out_in_seconds) # min is 5 seconds, affects both telnet and FTP
The same function can also be used to get the current timeout...
Cheers,
Daniel
Post by pythoncoder » Sat Oct 17, 2015 12:27 pm
Post by Roberthh » Wed Oct 21, 2015 3:54 pm
Looks like network.server_timeout() disappeared with todays update.
Instead there is something like network.server.timeout(), but giving a number as argument just results in an error. Any update on the API doc?
Regards
danicampora
Post by danicampora » Wed Oct 21, 2015 4:02 pm
Docs will be generated later today, along with the official release. Do
from network import server
server = server(timeout=value_in_seconds)
Post by Roberthh » Wed Oct 21, 2015 4:46 pm
Thank you very much for the fast reply. That works,
