Setting pin alternate function
Looking at the PWM example http://micropython.org/resources/docs/e ... modulation
some things have changed - Pin.ALT instead of Pin.AF and I can do these:
>>> p24 = Pin('GP24',Pin.ALT)
>>> p24.alt_list()
[('UART1_RX', 2), ('TIM3_CC0', 4), ('TIM0_PWM0', 5), ('I2C0_SDA', 9)]
How to set the alternate function? af=9 just gets a type mismatch
>>> p24 = Pin('GP24',Pin.ALT,af=9)
TypeError: argument num/types mismatch
>>> p24.alt_list()
- danicampora
Re: Setting pin alternate function
Ha - thought I'd tried that somewhat obvious variation but guess not - that works! thanks.
>>> p24 = Pin('GP24',Pin.ALT,alt=5)
I'll readup on Timers to adapt it to GP24 as I don't see 25 on the pinout. This stab didn't work:
>>> p24.alt_list()
>>> from machine import Timer
>>> tim = Timer(0,mode=Timer.PWM,width=16)
OSError: resource not available
>>> p24.alt_list()
GP25 is connected to the heartbeat LED on the wipy
I have some issues getting the timer.channel part working.
I can set the channel to Timer.A or Timer.B, however changing freq or duty cycle does not work. This is with update WyPi to version 1.1
>>> gp = 'GP10'
>>> pout = Pin(gp, mode=Pin.ALT)
>>> for x in pout.alt_list(): # why should I find the alt number for PWM of the system already knows it
... if 'PWM' in x[0]:
... pout = Pin(gp, mode=Pin.ALT, alt=x[1])
>>> print('pout:', pout)
pout: Pin('GP10', mode=Pin.ALT, pull=None, drive=Pin.MED_POWER, alt=12)
>>> tim = Timer(3, mode=Timer.PWM, width=16)
>>> tim_chA = tim.channel(Timer.A)
>>> tim_chA.freq(440)
AttributeError: no such attribute
>>> tim_chA.duty_cycle(50)
- danicampora
You need to provide at least the frequency for the timer channel to be initialized:
I know that the Timer API is inconsistent... we really need to define a proper one as part of the new Hardware API.
tim_a = tim.channel(Timer.A, freq=10000)
That is what I tried first and did not work either, so I tried doing it step by stepdanicampora wrote:Hi,
I know that the Timer API is inconsistent... we really need to define a proper one as part of the new Hardware API.Code: Select all
tim_chA = tim.channel(Timer.A, freq=1000)
ValueError: invalid argument(s) value
- danicampora
The frequency is too low for a 16 bit timer (PWMs are always 16 bit on the CC3200), set it to 10KHz. The error messages also need improvement, will work on it.
I'm not yet familiar with the WiPy way of doing things, but on the stm, the frequency is associated with the timer and not with a timer channel.
