I'm trying to use the examples in this thread to send e-mail from a Wemos D1 mini ESP8266 loaded with micropython.
It already fails at the first line: >>>import smtplib
ImportError: no module named 'smtplib'
Q: how to import module smtplib ? (or module curl ?)
Sending email
Re: Sending email
[quote=henkoegema post_id=30530 time=1538143662 user_id=4304]
[/quote]
I made small progress.
After downloading from: https://github.com/micropython/micropython-lib I could import smtplib. (but not module curl)
I'm trying this example:
>>> import smtplib
>>> efrom = 'me@yahoo.com'
>>> eto = 'you@gmail.com'
>>> header = 'To: {} \nFrom: {} \nSubject: Email from my WiPy\n\n'.format(efrom, eto)
>>> msg = header + 'Hi,\nThis is the WiPy emailing
\n'
>>> smtpserver = smtplib.SMTP('smtp.mail.yahoo.com', 465) <---------------------
>>> smtpserver.helo()
(250, b'smtp.mail.yahoo.com')
>>> smtpserver.login(efrom, 'ypassword')
(235, b'2.0.0 OK')
>>> smtpserver.sendmail(efrom, eto, msg)
>>> smtpserver.close()
Here it fails:
>>> smtpserver = smtplib.SMTP('smtp.mail.gmail.com', 465)
AttributeError: 'module' object has no attribute 'SMTP' <---------------------
[/quote]
>>> import smtplib
>>> smtpserver.helo()
(235, b'2.0.0 OK')
>>> smtpserver.close()
Here it fails:
Re: Sending email
[quote=dhylands post_id=6055 time=1445443348 user_id=81]
I know you can send emails using just telnet (http://www.yuki-onna.co.uk/email/smtp.html) so you should be able to do it without smtplib.
[/quote]
Not Found
The requested URL /email/smtp.html was not found on this server.
[/quote]
Not Found
Re: Sending email
While this thread was helpful in getting SMTP email working on the ESP8266, I found this (hopefully will help others): https://blog.thepodnet.com/sending-mail-using-nodemcu/
To make it work with Hotmail (gmail got too hard with their "insecure" login controls), I had to add an extra "\n" after the Subject line.
If the link disappears, I'll send his code.
Re: Sending email
Seeing this link https://blog.thepodnet.com/sending-mail-using-nodemcu/ has disappeared, here's his code (Not mine).
This works with Hotmail (and derivatives) with the attached "umail.py".
Updated 8/9/20: https://github.com/shawwwn/uMail
import umail
smtp = umail.SMTP('smtp.live.com', 587) #
smtp.login('<email>@hotmail.com', '<password>') # Your login, and password in clear text
smtp.to('<email>') # Full email address of recipient
smtp.write("From: Joe Blogs <j_blogs@hotmail.com>\n") # This is just a string
smtp.write("To: John Doe <j_doe@hotmail.com>\n") # This is just a string
smtp.write("Subject: This is Test\n")
smtp.write("\n") # This line is essential
smtp.write("Yay!\n") # 1st line of email body
smtp.write("It's Working\n")
smtp.write("...\n") # This line is essential
smtp.send()
smtp.quit()
- umail.zip
- A usocket based email module
- (1.38 KiB) Downloaded 53 times
Re: Sending email
Thanks for posting. Didn't work on my Hotmail account but adding the lines:
... got me the subject line I needed in my working Gmail(no 2step auth) version .
Appreciate you taking the time to post.
Dave
Dave
Re: Sending email
The RFC prescribes that all lines in a message must end with CR + LF (i.e. '\r\n') not only a single line-feed. Most mail clients and server tolerate line-feed-only line endings, though, but...
