Timer example not working
Post by deshipu » Thu Oct 22, 2015 7:02 pm
While exploring WiPy, I tried the example from the documentation on timers, at http://micropython.org/resources/docs/e ... hine-timer
tim = Timer(4)                                   # create a timer object using timer 4
tim.init(mode=Timer.PERIODIC)                    # initialize it in periodic mode
tim_ch = tim.channel(Timer.A, freq=2)            # configure channel A at a frequency of 2Hz
tim_ch.callback(handler=lambda t:led.toggle())   # toggle a LED on every cycle of the timer
(Before that, I disabled heartbeat and set
led = Pin('GP25', machine.Pin.OUT)
But that example doesn't work:
ValueError: invalid argument(s) value
What's wrong?
cswiger
Re: Timer example not working
Post by cswiger » Thu Oct 22, 2015 7:43 pm
I think you need to use a higher frequency than 2 - try 5 or more. The clock speed and max count are such that 5hz is about the lowest it can divide down to.
Mine's offline or I'd test it 8-)
danicampora
Post by danicampora » Thu Oct 22, 2015 8:21 pm
Hi guys,
The timer class is broken in too many places. Needs serious fixing ASAP. Apologies...
Cheers,
Daniel
cswiger
Post by cswiger » Thu Oct 22, 2015 11:49 pm
Ok, we'll wait. Getting past the op error (by using freq=5) I've run into this before:
AttributeError: no such attribute
>>> dir(tim_ch)
['freq', 'period', 'time', 'event_count', 'event_time', 'duty_cycle', 'irq']
robotmad
Post by robotmad » Thu Oct 29, 2015 11:48 pm
Is it also the case that the 'callback' method (mentioned in another example) has been replaced by 'irq'?
Oli_
Post by Oli_ » Tue Nov 17, 2015 11:35 pm
danicampora wrote:Hi guys,
Cheers,
Daniel
Hello Daniel,
Just to know if some work have been made to the Timer class ?
Best regards,
Olivier
Oli_
Post by Oli_ » Tue Nov 24, 2015 10:35 pm
cswiger wrote:Ok, we'll wait. Getting past the op error (by using freq=5) I've run into this before:
>>> dir(tim_ch)
If you want to use freq lower then 5 seconds, you can use a 32-bit width timer like that :
led = Pin('GP16', mode=Pin.OUT)
tim = Timer(1, mode=Timer.PERIODIC, width=32)
tim_ab = tim.channel(Timer.A|Timer.B, freq=1)
tim_ab.irq(handler=lambda t: led.toggle())
Post by deshipu » Sun Dec 20, 2015 9:37 am
So, is there any timeline or plan on when the timers are going to work? Without timers the WiPy is pretty much useless to me, so it would be nice to know if I should consider the money lost and just go and buy some other, working board. I see the example in the documentation is still wrong, raising a ValueError. I can make a pull request with a docs fix, but unfortunately can't really help with the API overhaul. Would it help if I reported this as an issue on Github?
v923z
Post by v923z » Mon Dec 28, 2015 6:33 pm
Daniel,
I don't want to be rude, or anything, and there might be millions of reasons for your not having time to fix something, but I would also agree with the previous post that the kickstarter campaign was not entirely honest (the kickstarter page even has an example demonstrating the use of timers, while these don't work on the shipped boards), and this board might have to be considered money down the drain. I believe, the first problem with the timer was reported at the end of September, and nothing has since happened. I think you'll agree that a microcontroller without timers is pretty much useless. The wipy was supposed to be the "Swiss Army knife of IoT", with "infinite possibilities", and "lots of fun". I am not entirely sure it has lived up to the promises...
Cheers,
Zoltán
Post by pythoncoder » Tue Dec 29, 2015 8:22 am
I notice there's a new firmware build out today (29th Dec). Perhaps this might fix it?
