Enterprise authentication, e.g. 802.1x EAP
Does the WiPy support more complex WiFi authentication schemes, such as 802.1x EAP? I can't see any reference to it in the API docs, which only mention WPA and the like.
- danicampora
Re: Enterprise authentication, e.g. 802.1x EAP
Hi, the underlying hardware does support it, but I haven't exposed it in the Python API yet. Perhaps if you have example use cases we can see how to do it
Thanks Dani. My use case is simply my office WiFi network, which is a 5GHz network (I assume the chip supports 5GHz?) using 802.1x EAP. It doesn't use a certificate or smart card, just a username and password, which is linked to Microsoft Active Directory using some sort of SSO solution. It would be really great if I could connect the WiPy to that network, but if not then I should be able to find a workaround.danicampora wrote:Perhaps if you have example use cases we can see how to do it
For example UPC Wi-Free. It makes available other UPC customers Wi-Fi router for UPC clients country wide and in other countries too.
http://www.upc-cablecom.ch/en/internet/wi-free/
HAM radio call: HA5DI (Béla)
Another example would be Eduroam, which gives the WiPy internet access in most educational institutions if you have an account in one of them.
- danicampora
Hi, thanks for all the feedback . I'll add WPA Enterprise support to the backlog!
I am also interested in this. I was running a scan of local stations and wipy couldn't return the ssid of my 5Ghz access point, so I had to enable 2.4. Is it supported by the hardware?allanlewis wrote:which is a 5GHz network (I assume the chip supports 5GHz?)
- danicampora
OK, so in my case the WiPy won't work because (to the best of my knowledge) my office network is 5GHz-only. Nevertheless, WPA Enterprise would be a nice addition.danicampora wrote:No, the hardware supports 2.4GHz only.
Our customer requires 5GHz as a future proofing option. Are there any plans to support 5GHz in future?danicampora wrote:No, the hardware supports 2.4GHz only.
