Connect over SSL
fjvillegas
Re: RE: Re: Connect over SSL
Post by fjvillegas » Sat Apr 15, 2017 10:51 pm
Hi Knoahlr,
I have the same problem. I did some workaround where the recommendation was to run "sock.connect" after the "ussl.wrap_socket". Unfortunately I'm seeing that the ussl library for ESP8266 doesn't have options to configure ssl_params. Besides that, socket.connect doesn't have IPPROTO_TCP as variable.
>>> import usocket
>>> dir(usocket)
['__name__', 'reset', 'callback', 'getaddrinfo', 'print_pcbs', 'socket', 'AF_INET', 'AF_INET6', 'SOCK_STREAM', 'SOCK_DGRAM', 'SOCK_RAW', 'SOL_SOCKET', 'SO_REUSEADDR']
Have you managed to run TSL on the ESP8266?
Best,
Francisco
sunrise17
Post by sunrise17 » Tue Apr 10, 2018 6:20 am
Hi fjvillegas,
Have you find some solution about pass through ssl_params to "sock.connect". Unfortunately, there is no ca_cert parameter inside ssl_args(line 59) following module below.
https://github.com/micropython/micropyt ... _mbedtls.c
However, in CC3200, i have seen inside the module below that its possible to configure SSL_params.
https://github.com/micropython/micropyt ... /modussl.c
May be it can be configured also for ESP8266 and ESP32 with this method as done in CC3200.
