MQTT publish
andrew
MQTT publish
Post by andrew » Mon Nov 02, 2015 9:51 pm
This is a hack. I repeat, this is a hack. Do not run your nuclear power station control system with it.
This code is a conversion of some javascript I found here http://forum.espruino.com/conversations/258515/ for the Espruino.
def mtStr(s):
  return bytes([len(s) >> 8, len(s) & 255]) + s.encode('utf-8')
def mtPacket(cmd, variable, payload):
  return bytes([cmd, len(variable) + len(payload)]) + variable + payload
def mtpConnect(name):
  return mtPacket(
           0b00010000,
           mtStr("MQTT") + # protocol name
           b'\x04' +       # protocol level
           b'\x00' +       # connect flag
           b'\xFF\xFF',    # keepalive
           mtStr(name)
def mtpDisconnect():
  return bytes([0b11100000, 0b00000000])
def mtpPub(topic, data):
  return  mtPacket(0b00110001, mtStr(topic), data)
import socket
import binascii
addr = socket.getaddrinfo("test.mosquitto.org", 1883)[0][4]
s = socket.socket()
print('Connecting...')
s.connect(addr)
s.send(mtpConnect("WiPy1"))
print(binascii.hexlify(s.recv(4096)))
print("Publishing...")
time.sleep(10)
s.send(mtpPub("wipytopic", b'wipy-data'))
time.sleep(10)
s.send(mtpPub("wipytopic", b'wipy-data-again'))
##print(binascii.hexlify(s.recv(4096)))
print('Disconnecting...')
s.send(mtpDisconnect())
s.close()
Andrew
