socket.sendto
socket.sendto
any Idea if UDP socket.sento method will be supported in future?
- danicampora
Re: socket.sendto
It's been supported since the first software release...
https://micropython.org/resources/docs/ ... ket.sendto
What makes you think it's not? Is there something not working for you?
Cheers,
Daniel
Cheers,
Daniel
Re: socket.sendto
Uh... I had the wrong documentation (ESP8266)
however, this code works with python34, but on wipy it throws the following error:
File "main.py", line 157, in <module>
File "ArtNet.py", line 66, in send_single_value
File "ArtNet.py", line 122, in __ArtDMX_broadcast
ValueError: invalid arguments
MicroPython v1.5-105-g50f5622 on 2015-11-09; WiPy with CC3200
This is line > self.s.sendto(result, (self.ip, self.port))
import socket
import struct
class ArtNet():
packet_counter = 1
dmxdata = [0, 0]
def __init__(self, artnet_net, artnet_subnet, artnet_universe, ip, port):
self.s = socket.socket(socket.AF_INET, socket.SOCK_DGRAM)
self.net = int(artnet_net)
self.subnet = int(artnet_subnet)
self.universe = int(artnet_universe)
self.ip = ip
self.port = int(port)
print(self.port)
#logger.debug("Init ArtNet Plugin done")
def run(self):
pass
def stop(self):
self.close()
def __call__(self, var1=None, var2=None):
if type(var1) == int and type(var2) == int:
self.send_single_value(var1, var2)
if type(var1) == int and type(var2) == list:
self.send_frame_starting_at(var1, var2)
if type(var1) == list and type(var2) == type(None):
self.send_frame(var1)
def send_single_value(self, adr, value):
if adr < 1 or adr > 512:
#logger.error("DMX address %s invalid" % adr)
return
while len(self.dmxdata) < adr:
self.dmxdata.append(0)
self.dmxdata[adr - 1] = value
self.__ArtDMX_broadcast()
def send_frame_starting_at(self, adr, values):
if adr < 1 or adr > (512 - len(values) + 1):
#logger.error("DMX address %s with length %s invalid" %
# (adr, len(values)))
return
while len(self.dmxdata) < (adr + len(values) - 1):
cnt = 0
for value in values:
self.dmxdata[adr - 1 + cnt] = value
cnt += 1
def send_frame(self, dmxframe):
if len(dmxframe) < 2:
#logger.error("Send at least 2 channels")
return
self.dmxdata = dmxframe
def __ArtDMX_broadcast(self):
# logger.info("Incomming DMX: %s"%self.dmxdata)
# New Array
data = []
# Fix ID 7byte + 0x00
data.append("Art-Net\x00")
# OpCode = OpOutput / OpDmx -> 0x5000, Low Byte first
data.append(struct.pack('<H', 0x5000))
# ProtVerHi and ProtVerLo -> Protocol Version 14, High Byte first
data.append(struct.pack('>H', 14))
# Order 1 to 255
data.append(struct.pack('B', self.packet_counter))
self.packet_counter += 1
if self.packet_counter > 255:
self.packet_counter = 1
# Physical Input Port
data.append(struct.pack('B', 0))
# Artnet source address
data.append(
struct.pack('<H', self.net << 8 | self.subnet << 4 | self.universe))
# Length of DMX Data, High Byte First
data.append(struct.pack('>H', len(self.dmxdata)))
# DMX Data
for d in self.dmxdata:
data.append(struct.pack('B', d))
# convert from list to string
result = bytes()
for token in data:
try: # Handels all strings
result = result + token.encode('utf-8', 'ignore')
except: # Handels all bytes
def close(self):
self.s.close()
if __name__ == '__main__':
artnet_subnet = 0
artnet_net = 0
artnet_universe = 0
ip = 'localhost'
port = 6454
sh = ArtNet(artnet_net, artnet_subnet, artnet_universe, ip, port)
value = 0
sh.send_single_value(12,value)
time.sleep(1)
if (value < 254):
value +=1
value = 0
- danicampora
Re: socket.sendto
Umm, should work. Can you provide a smaller snippet that shows the error? Could it be the IP format? IPv6 is not supported by the way...
Re: socket.sendto
Better?
import socket
import struct
class ArtNet():
packet_counter = 1
dmxdata = [0, 0]
self.ip = ip
print(self.port)
return
data = []
data.append(
result = bytes()
for token in data:
def close(self):
self.s.close()
artnet_subnet = 0
artnet_net = 0
artnet_universe = 0
ip = 'localhost'
port = 6454
sh.send_single_value(12,100)
- danicampora
Re: socket.sendto
The problem is with ip being 'localhost', this is not supported. Use: '127.0.0.1' instead...
Sorry that I didn't see it in the first snippet.
Re: socket.sendto
Ahhrrrr!
Yep - that was easy, don't know why I did not realized it - thank you !
Works now, but I have another question...
Raw performance is ~130 packets/s (I was just curious)
I reduced to ~30 packets/s but however the light is not dimming smoothly.
With my artnet software on my PC i can see a history for the specific
channel - Time and Value.
Seems Wipy is not sending the packets consistent - is there any thing I can do
to improve this?
Many Thanks!
to improve this?
Many Thanks!
Re: socket.sendto
Here is a litte illustration - The upper graphic shows artnet-packets received in the timeline,
thats how I want it to look.
The bottom graphic is the artnet-traffic when using the wipy (using soure above) Looks like its collecting (buffering) some
data before sending (height of Bars means amount of data).
Maybe sleep() is not accurate and I have to use a periodic timer.
Sorry to ask - I do not have enough background knowledge of the Hardware so I could understand why this happens.
- danicampora
Re: socket.sendto
Can you show the code that you use to send periodically? On your first snippet, you do, this will send something every 1 second. Try using time.sleep_ms instead.
time.sleep(1)
Re: socket.sendto
yes I used "time.sleep_ms(30)"
With this I do get a framerate of ~20 Packets/s in my Artnet monitor.
But the problem is that five packets are send within some ms - followed by a longer break ~200ms.
