Wipy flash/source code security.
beyonlo
Post by beyonlo » Thu Nov 26, 2015 8:14 pm
Hi all!
1. Is possible to run .pyo to wipy instead a .py? To be more secure - imagine I put in the source code some keys to do something or so on.
2. How is flash protection if someone steal my wipy and try to get the data and/or read my python scripts? I would like that will be not possible to get my python files, for the same reason of item 1. Becouse .pyo still easy to broken.
I would like to use wipy for a security systems for access control.
Thanks.
Re: Wipy flash/source code security.
Post by dhylands » Thu Nov 26, 2015 9:15 pm
Most MCUs have one time programmable bits that allow you to protect things like code and stuff, but its generally rather tricky to get right. Especially if you want to be able to update things.
.pyo files are no more secure than source code (it's essentially trivial to get a disassembly of the bytecode).
I know when someone asked about the pyboard and this same topic, it basically boiled down that its up to you do the work if you want that kind of functionality. The required information is normally in the datasheet.
danicampora
Post by danicampora » Thu Nov 26, 2015 9:35 pm
Such mechanism is on the roadmap for the WiPy. At the end, your .py files will be AES encrypted with a key that you can save in a special register of the MCU (via an MP API call) that no body will be able to read. The encrypted file could have a .pyx (or whatever) extension that is detected by the lexer (mp_lexer_new_from_file) so that it knows that the file needs to be decrypted. The WiPy has a built-in hardware AES engine. You would store the key in the device once during manufacturing (via the REPL for example). Does this make sense to you?
beyonlo
Post by beyonlo » Mon Nov 30, 2015 12:08 am
Yes, that make sense.
What is the roadmap for this feature will be ready?
beyonlo
Post by beyonlo » Sat Dec 12, 2015 4:55 pm
Hello danicampora,
Yes, that make sense. So, when that feature will be ready?
danicampora
Post by danicampora » Sat Dec 12, 2015 5:09 pm
Sorry for the late reply. Early next year, I hope.
beyonlo
Post by beyonlo » Sun Dec 13, 2015 1:52 am
Hi danicampora,
Thank you.
