os.urandom... isn't very random?
gpshead
Post by gpshead » Sun Dec 20, 2015 1:22 am
Plotting the output of os.urandom(512) to a bitmap display is disturbingly non-random:
Re: os.urandom... isn't very random?
Post by dhylands » Sun Dec 20, 2015 1:37 am
What did you plot (i.e. what is the X axis and what is the Y axis)?
Post by Roberthh » Sun Dec 20, 2015 8:55 pm
I made two tests. For PyBoard, I collected sufficient data to run the NIST800-22 test. It passed all tests.
For WiPy, I just collected 16k Bytes and just looked at the histogram, the simple plot (value vs. index) , a scatterplot( first half vs. second half) and a spectrogram. None of that looks obviously wrong. For the NIST test, I need about 120 MByte of data. To get these from Wipy requires a little bit more of programming than 5 lines of code. So it'll take a while.
danicampora
Post by danicampora » Sun Dec 20, 2015 9:19 pm
The pyboard has a true harward random number generator, while the WiPy on the other hand as a software pseudo random one. The WiPy one is good enough in most cases, but I doubt it'll pass the NIST tests...
Cheers,
Daniel
Post by Roberthh » Mon Dec 21, 2015 1:39 pm
A good pseudo-random number generator with a sufficiently long period should pass the NIST test, because this test looks for randomness, not for predictability. And if you are using an algorithm like AES or DEA in feedback mode for the generator, that should work. Looking at the code I see that WiPy uses a 24 bit LFSR. I extracted that into a little C program. generated data and did the NIST test on it. It did not fail every test. Bruce Schneier has published two other examples, which perform better, if that is of any matter.
https://www.schneier.com/cryptography/a ... equen.html
willie
Post by willie » Thu Dec 31, 2015 5:21 am
It's really not ok for os.urandom to use an LSFR generator. It's supposed to be cryptographically secure. If there is a way to initialize it through user input timings or something, then running a cryptographic PRNG is hopefully ok. But it would be good if there was some NVRAM or something to maintain the PRNG state between powerups.
cswiger
Post by cswiger » Tue Feb 09, 2016 8:31 pm
Collected about 4MB of os.urandom(1024) concatenated and ran this test (where ocassional low or high p values will occasionally occur in a good trng, that is, in another collection that one weak will go away and maybe another will appear elsewhere, it happens):
chuck@pe1950b:~$ dieharder -a -f bigrand
#            dieharder version 3.31.1 Copyright 2003 Robert G. Brown          #
   rng_name    |           filename             |rands/second|
        mt19937|                         bigrand|  1.25e+08  |
        test_name   |ntup| tsamples |psamples|  p-value |Assessment
   diehard_birthdays|   0|       100|     100|0.61695785|  PASSED
      diehard_operm5|   0|   1000000|     100|0.03918532|  PASSED
  diehard_rank_32x32|   0|     40000|     100|0.00254075|   WEAK
    diehard_rank_6x8|   0|    100000|     100|0.32426917|  PASSED
   diehard_bitstream|   0|   2097152|     100|0.90983775|  PASSED
        diehard_opso|   0|   2097152|     100|0.31136592|  PASSED
        diehard_oqso|   0|   2097152|     100|0.88849299|  PASSED
         diehard_dna|   0|   2097152|     100|0.02632160|  PASSED
diehard_count_1s_str|   0|    256000|     100|0.53418033|  PASSED
diehard_count_1s_byt|   0|    256000|     100|0.10833179|  PASSED
 diehard_parking_lot|   0|     12000|     100|0.40756286|  PASSED
    diehard_2dsphere|   2|      8000|     100|0.62485804|  PASSED
    diehard_3dsphere|   3|      4000|     100|0.96434579|  PASSED
     diehard_squeeze|   0|    100000|     100|0.92749868|  PASSED
        diehard_sums|   0|       100|     100|0.31733302|  PASSED
        diehard_runs|   0|    100000|     100|0.76171815|  PASSED
        diehard_runs|   0|    100000|     100|0.53259081|  PASSED
       diehard_craps|   0|    200000|     100|0.06443498|  PASSED
       diehard_craps|   0|    200000|     100|0.95361196|  PASSED
 marsaglia_tsang_gcd|   0|  10000000|     100|0.07229466|  PASSED
 marsaglia_tsang_gcd|   0|  10000000|     100|0.80494213|  PASSED
         sts_monobit|   1|    100000|     100|0.01221109|  PASSED
            sts_runs|   2|    100000|     100|0.19410883|  PASSED
          sts_serial|   1|    100000|     100|0.43740452|  PASSED
          sts_serial|   2|    100000|     100|0.76149357|  PASSED
          sts_serial|   3|    100000|     100|0.43520694|  PASSED
          sts_serial|   3|    100000|     100|0.76020044|  PASSED
          sts_serial|   4|    100000|     100|0.76252435|  PASSED
          sts_serial|   4|    100000|     100|0.97424261|  PASSED
          sts_serial|   5|    100000|     100|0.24626500|  PASSED
          sts_serial|   5|    100000|     100|0.81633438|  PASSED
          sts_serial|   6|    100000|     100|0.26457489|  PASSED
          sts_serial|   6|    100000|     100|0.69164995|  PASSED
          sts_serial|   7|    100000|     100|0.46649650|  PASSED
          sts_serial|   7|    100000|     100|0.92070611|  PASSED
          sts_serial|   8|    100000|     100|0.56905248|  PASSED
          sts_serial|   8|    100000|     100|0.90358265|  PASSED
          sts_serial|   9|    100000|     100|0.93444552|  PASSED
          sts_serial|   9|    100000|     100|0.99458113|  PASSED
          sts_serial|  10|    100000|     100|0.86543565|  PASSED
          sts_serial|  10|    100000|     100|0.40262869|  PASSED
          sts_serial|  11|    100000|     100|0.88516655|  PASSED
          sts_serial|  11|    100000|     100|0.94037598|  PASSED
          sts_serial|  12|    100000|     100|0.75323099|  PASSED
          sts_serial|  12|    100000|     100|0.85525976|  PASSED
          sts_serial|  13|    100000|     100|0.87538565|  PASSED
          sts_serial|  13|    100000|     100|0.57705181|  PASSED
          sts_serial|  14|    100000|     100|0.44317210|  PASSED
          sts_serial|  14|    100000|     100|0.58562576|  PASSED
          sts_serial|  15|    100000|     100|0.18821489|  PASSED
          sts_serial|  15|    100000|     100|0.46040268|  PASSED
          sts_serial|  16|    100000|     100|0.83894356|  PASSED
          sts_serial|  16|    100000|     100|0.73328515|  PASSED
         rgb_bitdist|   1|    100000|     100|0.53312740|  PASSED
         rgb_bitdist|   2|    100000|     100|0.73311971|  PASSED
         rgb_bitdist|   3|    100000|     100|0.74776632|  PASSED
         rgb_bitdist|   4|    100000|     100|0.92487323|  PASSED
         rgb_bitdist|   5|    100000|     100|0.06238251|  PASSED
         rgb_bitdist|   6|    100000|     100|0.95538826|  PASSED
         rgb_bitdist|   7|    100000|     100|0.98758602|  PASSED
         rgb_bitdist|   8|    100000|     100|0.72461133|  PASSED
         rgb_bitdist|   9|    100000|     100|0.72909151|  PASSED
         rgb_bitdist|  10|    100000|     100|0.16866374|  PASSED
         rgb_bitdist|  11|    100000|     100|0.94563096|  PASSED
         rgb_bitdist|  12|    100000|     100|0.84388674|  PASSED
rgb_minimum_distance|   2|     10000|    1000|0.05088220|  PASSED
rgb_minimum_distance|   3|     10000|    1000|0.49882948|  PASSED
rgb_minimum_distance|   4|     10000|    1000|0.84127071|  PASSED
rgb_minimum_distance|   5|     10000|    1000|0.41340460|  PASSED
    rgb_permutations|   2|    100000|     100|0.24236399|  PASSED
    rgb_permutations|   3|    100000|     100|0.89899169|  PASSED
    rgb_permutations|   4|    100000|     100|0.62104572|  PASSED
    rgb_permutations|   5|    100000|     100|0.19781278|  PASSED
      rgb_lagged_sum|   0|   1000000|     100|0.49335812|  PASSED
      rgb_lagged_sum|   1|   1000000|     100|0.57442446|  PASSED
      rgb_lagged_sum|   2|   1000000|     100|0.72623778|  PASSED
      rgb_lagged_sum|   3|   1000000|     100|0.76799308|  PASSED
      rgb_lagged_sum|   4|   1000000|     100|0.02997482|  PASSED
      rgb_lagged_sum|   5|   1000000|     100|0.18870353|  PASSED
      rgb_lagged_sum|   6|   1000000|     100|0.43936165|  PASSED
      rgb_lagged_sum|   7|   1000000|     100|0.38212618|  PASSED
      rgb_lagged_sum|   8|   1000000|     100|0.21711583|  PASSED
      rgb_lagged_sum|   9|   1000000|     100|0.03174413|  PASSED
      rgb_lagged_sum|  10|   1000000|     100|0.78621228|  PASSED
      rgb_lagged_sum|  11|   1000000|     100|0.07425169|  PASSED
      rgb_lagged_sum|  12|   1000000|     100|0.65158704|  PASSED
      rgb_lagged_sum|  13|   1000000|     100|0.31547852|  PASSED
      rgb_lagged_sum|  14|   1000000|     100|0.86615011|  PASSED
      rgb_lagged_sum|  15|   1000000|     100|0.94580508|  PASSED
      rgb_lagged_sum|  16|   1000000|     100|0.90628965|  PASSED
      rgb_lagged_sum|  17|   1000000|     100|0.42661627|  PASSED
      rgb_lagged_sum|  18|   1000000|     100|0.92157677|  PASSED
      rgb_lagged_sum|  19|   1000000|     100|0.60133352|  PASSED
      rgb_lagged_sum|  20|   1000000|     100|0.52296843|  PASSED
      rgb_lagged_sum|  21|   1000000|     100|0.37980474|  PASSED
      rgb_lagged_sum|  22|   1000000|     100|0.98505308|  PASSED
      rgb_lagged_sum|  23|   1000000|     100|0.86384453|  PASSED
      rgb_lagged_sum|  24|   1000000|     100|0.91244148|  PASSED
      rgb_lagged_sum|  25|   1000000|     100|0.41447060|  PASSED
      rgb_lagged_sum|  26|   1000000|     100|0.68715712|  PASSED
      rgb_lagged_sum|  27|   1000000|     100|0.06450373|  PASSED
      rgb_lagged_sum|  28|   1000000|     100|0.76268183|  PASSED
      rgb_lagged_sum|  29|   1000000|     100|0.86828993|  PASSED
      rgb_lagged_sum|  30|   1000000|     100|0.65213018|  PASSED
      rgb_lagged_sum|  31|   1000000|     100|0.22795356|  PASSED
      rgb_lagged_sum|  32|   1000000|     100|0.04675176|  PASSED
     rgb_kstest_test|   0|     10000|    1000|0.02459689|  PASSED
     dab_bytedistrib|   0|  51200000|       1|0.51907397|  PASSED
             dab_dct| 256|     50000|       1|0.98987543|  PASSED
Preparing to run test 207.  ntuple = 0
        dab_filltree|  32|  15000000|       1|0.52251896|  PASSED
        dab_filltree|  32|  15000000|       1|0.25957927|  PASSED
Preparing to run test 208.  ntuple = 0
       dab_filltree2|   0|   5000000|       1|0.29477193|  PASSED
       dab_filltree2|   1|   5000000|       1|0.68797791|  PASSED
Preparing to run test 209.  ntuple = 0
        dab_monobit2|  12|  65000000|       1|0.16430290|  PASSED
