I would like to extend the WiFi range of the WiPy.
Is it as simple as plugging an external antenna into the ANT2 connector?
If so, can anyone recommend a suitable WiFi antenna?
Thanks!
Chuck McLellan
External WiFi Antenna
Re: External WiFi Antenna
You will also have to choose WLAN.EXT_ANT during initialisation of the network, or with the method wlan.antenna(). Have a look at the documentation here:
http://micropython.org/resources/docs/e ... twork.html
I tried it using an antenna from a 2.4 GHz RC transmitter with better range than the one on the WiPy PCB. Can't really recommend anything.
