Hello. I've purchased two WiPy. Today I started playing with them, but one of those is not working. It has the heartbeat led permanently on, wifi SSID is not visible, /dev/ttyUSB0 is visible but connecting to it with screen I got no response.
Also, on the Wipy thats working, I can connect via Wifi to it, but it doesn't seem to be working the connection via USB (ttyUSB0 appears, but when I connect with screen I get blank screen and nothing happends even while I type).
Thanks!!
WiPy not working
Re: WiPy not working
For the serial to work, there are a few things you need to put in your boot.py. See:
http://micropython.org/resources/docs/e ... /repl.html
Thanks! I will do that on the one that's working. Still no idea on what to do with the board thats not working.
