A stupid mistake on the boot.py forced me to do a "safe" boot. Connected the 3.3v to the GP28, did a reset and it is not starting anymore.
![Sad :(](./images/smilies/icon_e_sad.gif)
Please, does someone have any trick or advice to try on the board ?
Hey!Roberthh wrote:Shorting the 3.3 output to GND should not hurt. The 3.3 regulator of the WiPy is current limited at 2.8 Amps and thermally protected, the switching transistor at the input is rated at > 6 Amps. That looks all pretty robust. Can you tell, whether there is still 3.3 V on the output? How do you supply the Wipy? Is Vin fine?
