WiPy USB connectivity and Automatic Home Network Configuration
DWiskow
Post by DWiskow » Sun May 22, 2016 10:04 pm
I configured my WiPy to auto connect to my home WiFi when in range and automatically setup up its default AP when not at home using the following code in 'main.py'
# main.py -- auto connect to specified WiFi if available, otherwise fires up 'wipy-wlan-xxxx' Access Point
#         -- enables CTRL-D soft resets without loss of connection when using Telnet or FTP
from network import WLAN
wlan = WLAN()
print()
if (wlan.isconnected() and machine.reset_cause() == machine.SOFT_RESET):
	print(wlan.ifconfig())
	print()
	if machine.reset_cause() != machine.SOFT_RESET:
		wlan = WLAN(mode=WLAN.STA)
		nets = wlan.scan()
		for net in nets:
			if net.ssid == 'MY SSID':
				wlan.ifconfig(config=('192.168.1.255', '255.255.255.0', '192.168.1.1', '8.8.8.8'))
	if not wlan.isconnected():
		nets = wlan.scan()
		for net in nets:
				wlan.connect(ssid='MY SSID', auth=(WLAN.WPA2, 'MY PASSWORD'))
				currTime = time.time()
				while not wlan.isconnected():
					if (time.time()-currTime > 15):
						break
        			time.sleep_ms(250)
		if wlan.isconnected():
			print("WLAN connection to 'MY SSID' WiFi succeeded!")
			wlan = WLAN(mode=WLAN.AP)
			print("WLAN '"+wlan.ssid()+"' AP WiFi Available!")
	print()
I also configured 'boot.py' to duplicate the terminal console via the UART to the USB on the expansion board and auto mount its micro SD card
# boot.py -- run on boot-up
# can run arbitrary Python, but best to keep it minimal
from machine import SD
import os
uart = UART(0, 115200)
os.dupterm(uart)
# clock pin, cmd pin, data0 pin
sd = SD(pins=('GP10', 'GP11', 'GP15'))
sd = SD()
os.mount(sd, '/sd')
The code in 'main.py' enables soft resets [using CTRL-D] without disconnecting a Telnet or FTP session
rodrigob
Re: WiPy USB connectivity and Automatic Home Network Configuration
Post by rodrigob » Tue Jun 07, 2016 8:03 am
Great, thanks for sharing the example !
