Hi guys,
pondering over what board I will buy, I thought about WiPy, Esp8266 and Raspberry Pi 3.
Being really a "software" kind of person, I think experimenting with servo's etc. is not my thing.
What I do like about WiPy:
1. experimenting with simple sensors and Wifi is possible
2. low energy consumption of the WiPy.
3. MicroPython is awesome (also no OS needed, which gives a lot of overhead)
4. lots of IoT possibilities
5. excellent documentation of WiPy and MicroPython
Question 1: Would there be any reason to not go for the WiPy?
When I would buy the WiPy, I think I need:
1. WiPy itself
2. expansion board
3. class 10 16GB SD card
4. a case
Question 2: do I need to buy more stuff to get things going?
Question 3: is there a central place with IoT related projects / examples on the WiPy
TIA,
hotcore
Choice of board
Re: Choice of board
Raspberry Pi is not a microcontroller.
While the RaspberryPi is great, it is not a microcontroller, this means it is a self-hosting system - you can compile, build etc, stuff on the Pi itself without another machine.
This is not true of the other boards, even if it's technically possible to edit the Python code on the device - I still wouldn't recommend it for normal dev work
Re: Choice of board
If you are mostly interested in programming and not on building things, I think you will be much happier with a Raspberry Pi. As written above, it's a complete computer, and offers much greater possibilities for your programs in terms of languages, resources, debugging tools and learning materials available. It stills lets you connect and play with electronics, so you can get your feet wet slowly.
Re: Choice of board
Looking at the initial questions, I cannot give a good advice. If programming flexibility it most important, then Raspi is it. If Low Power, fast start-up and possible battery operation is more important, the WiPy or one of the other micros are the better choice.
But they all do not cost too much. You can try both, like many of us here have all possible boards to try them, and at the end you get the one best suited for a special task. The common denominator then is MicroPython.
Best Regards
Best Regards
Re: Choice of board
Thx for all replies!
For now I think the WiPy is closest to what I like.
Maybe later I'll try the RPi.
Re: Choice of board
Also
I would not quite agree. There is some documentation, but it is not great.
Another big difference (which I noted when porting code from RPi to Wipy), is that the Wipy processor is much slower than RPi; so if computation speed is part of the equation, this should be taken into account.
Re: Choice of board
A few things about the wipy that weren't mentioned here.
- The wipy does not support floating point. while the esp8266 does.
- The wipy boards don't have onboard power, so using it without the expansion board requires an external power supply.
- The wipy firmware does not get frequent updates. The current release firmware is from February and is quite old.
hotcore wrote:Hi guys,
1. WiPy itself
2. expansion board
4. a case
TIA,
hotcore
Re: Choice of board
Thx again!
Today the choice was made by my family, because they gave me a RPi3 for father's day:
