I am trying to perform OTA update via FTP, but my Filezilla client reports 'Could not start transfer' when trying to upload mcuimg.bin to '/flash/sys'.
When I try to upload the file to '/flash' it works however reported file size of uploaded file is smaller as it probably cannot fit in that part of FS.
Current version is v1.7-153-gbd66b09 on 2016-04-25, os.uname().release returns '1.2.0'.
OTA update issue
Re: OTA update issue
verify that you are using passive mode with a single connection.
And you could alternatively try the command line version
ftp -p ip_of_wipy
Yes, I use passive mode. Uploading to other directories than '/flash/sys' works ok. I work in Windows, but you are right, I should try different client. Anyway I think it will not help.
In my experience Filezilla is utterly reliable.
