Pre-Compiled files using more memory?
Yesterday I ran into memory allocation failed issues.
My understanding is that pre-compiling the modules would help alleviate those issues. So, I made the modifications to the code as mentioned here (viewtopic.php?t=1962 ), compiled and flashed the WiPy successfully.
I compiled several modules using mpy-cross, uploaded to WiPy and restarted.
I'm now seeing that there is much less memory available using gc.mem_free(). Even after running a GC there is less memory than before I pre-compiled the modules.
Am I missing something?
Thanks,
aw
Thanks,
aw
Re: Pre-Compiled files using more memory?
Hello @tallyboy91. For Wipy you just need the change to mpconfigport.h:
For RAM usage please note, that at runtime the precompiled modules use the same amount of RAM than the straight ones. It just saves RAM during compile time and allows to compile much larger modules. If you tell that you now have much less RAM, it could be caused by now loading a more recent version of MicroPYthon with more features. On WIPy, all code is run from RAM, so the newly added code also requires some RAM. On my system (V 1.8.1) after boot w/o any modules loaded, there is about 50k of RAM available. What are your figures?
#define MICROPY_PERSISTENT_CODE_LOAD (1)
It's been one of those days... I wanted to get some concrete numbers on the differences and ran into problems where importing a module would only show module.__name__. Then I wasn't paying attention and blew away my main.py file without a backup of course
Anyway, to answer your question, I have about 50K of free memory using 1.8.3 when I have no extra modules loaded.
I ran a test of loading regular modules with the normal 1.8.3 binary and then compared it to using only .mpy modules. To your point, there was a negligible difference in memory usage.
What I did finally figure out (and maybe this will help other people) is that I had been running out of space (RAM) when flashing/uploading files. In my hurry (and ignorance), I didn't pay attention to the fact that modules were just blank files. And they imported without any errors so I didn't realize what was happening. Lesson learned the hard way.
Admittedly, I'm going to have to change my mindset to focus on memory usage above just about everything else. A bit of a paradigm shift for me.
On a somewhat related note... if I put all my modules/files on a MicroSD card, can I bump up the memory available for running/compiling python code? I'm assuming I could somewhere in the code but have no clue where to begin. Plus my C "skills" are laughable.
Thanks!
aw
Thanks!
aw
Sorry, I did not see your reply earlier. As far as I understand, putting your files & code to SD card would not help. The CC3200 has not built-in flash. All code is loaded from external flash to RAM and executed there, and there is no paging mechanism like the ESP chip has, that would allow loading just the segments of code that are needed. Therefore RAM stays the limiting factor, and your code must fit into RAM during runtime. Pre-compiling avoids running out of memory at compile time, which is a difference.
If you compile on board, you are limited to about 400 lines of Python code. If pre-compiling, about 1500 lines of code should be OK, not considering the require data space. And pre-compiling will tell you immediately syntax errors.
@Roberthh
Thanks! This is great information and completely makes sense.
Currently, I'm using code for weather related sensors that has been ported over from the AdaFruit python code. It seems to me that the way to go is to first make sure that code works correctly. Then "optimize" it by removing any unneeded code as well as combining methods like read_raw_temp/read_temperature into a single method.
I'm also assuming that replacing constants such as BME280_REGISTER_CONTROL_HUM = 0xF2 to just 0xF2 within the code will also save space in heap? Admittedly, it certainly makes the code harder to read but I could always use the original code as a reference.
Are there any other tips/tricks on conserving memory?
Thanks!
aw
Thanks!
aw
Using constants instead of variables saves memory. Micropython has the syntax of:
which according to the spec is doing the same, by keeping readability. But there was a thread somewhere which objects to that claim. So it must be tested. In order to save memory and time at runtime, you should not reallocate buffers over and over again. So instead of
data = read(....)
you shoud
data= bytes(n)
readinto(data, ...)
or the like, just to explain the principle. This has been discussed at several places.
As long as you use mpy_cross, the source code style has no effect on memory usage. If you compile on-board, shorter source files are less likely to run out of memory during compile & load, but the exact rules are hard to define.
BME280_REGISTER_CONTROL_HUM = const(0xF2)
data = read(....)
you shoud
data= bytes(n)
readinto(data, ...)
@Roberthh Not quite, I'm afraid. The const() statement works as follows. If you write
the compiler will compile a = 5. In other words it will be faster and the code will be smaller because it won't perform a read from the MYCONST global. However the global will still use RAM. This is because another module might import MYCONST. To save RAM you need to write
In this case the global is unavailable for import, so MicroPython performs an additional optimisation and saves 4 bytes of RAM.
MYCONST = const(5)
def foo():
a = MYCONST
_MYCONST = const(5)
def foo():
a = _MYCONST
Aah, now I remember. That was the discussion about the leading underline and whther it's use is consistent in the Python space.
Great information! I need to start compiling a list of these kind of tips/optimizations.
So, is there already some list of tips/optimizations?
