urequests and SSL on WiPy
danielm
Post by danielm » Fri Sep 02, 2016 10:38 am
I am trying to perform HTTP GET request on https://www.google.com:
urequests.get("https://www.google.com")
Empty response is read from the socket which causes error I already encountered before: http://forum.micropython.org/viewtopic.php?f=15&t=2191
Anyway I think that SSL socket is not established correctly. I exported CA certificate in DER format as described here: http://processors.wiki.ti.com/index.php ... pplication
CA Certificate can be downloaded using various methods. For Example, On Windows 7 machine, procedure to Download CA Certificate of http://www.google.com is:
Press Start button
Typing certmgr.msc into the Search box, and then pressing ENTER.
Double Click Trusted Root Certificate Authorities
Double Click Certificate
Look for "Equifax Secure CA"
Double Click on it. It will open the Certificate.
Select Details Tab
Click on “Copy to File” button and export the certificate as .cer Format
Then I tried to flash it first time as "/cert/ca.pem" and second time as "/cert/129.der" as it is suggested in that wiki page. I always got empty response from the server.
Is there any way how to verify ssl socket?
Sending GET request to "http://www.google.com" returns redirect which is ok. I used urequests module version 0.4 from micropython-lib.
danielm
Re: urequests and SSL on WiPy
Post by danielm » Fri Sep 02, 2016 12:16 pm
Looking at urequests.py module it wraps the socket without any parameters on line 56:
s = ussl.wrap_socket(s)
In my understanding that means that ussl.wrap_scoket() is called with default values:
ssl.wrap_socket(sock, keyfile=None, certfile=None, server_side=False, cert_reqs=CERT_NONE, ca_certs=None)
To use flashed certificates I think it should be called with cert_reqs=ssl.CERT_REQUIRED, ca_certs='/flash/cert/ca.pem'
Not sure what this causes on server side.
jgmdavies
Post by jgmdavies » Fri Sep 02, 2016 1:01 pm
When creating the cert file, Win10 gives two options for .CER files:
  • - DER encoded binary X.509 (.CER)
    - Base-64 encoded X.509 (.CER)
Which is best for the WiPy code please?
Thanks,
Jim
ubiq_01
Post by ubiq_01 » Fri Sep 02, 2016 2:43 pm
I also worked with the urequests module yesterday (see https://twitter.com/_rac01/status/771378341270159360 ) - and in order to use it with SSL on the WiPy I had to modify
# s = usocket.socket()
s = usocket.socket(socket.AF_INET, socket.SOCK_STREAM, socket.IPPROTO_SEC)
(I used the module from a stock micropython-lib unix insstallation - maybe it has this SSL specific in the WiPy version already.)
best regards
Ralf
danielm
Post by danielm » Fri Sep 02, 2016 3:40 pm
Jim, DER format is mentioned in TI wiki I posted before.
Ralf, I will try that modification on Monday, thanks.
jgmdavies
Post by jgmdavies » Fri Sep 02, 2016 7:35 pm
Thanks, danielm.
danielm
Post by danielm » Sun Sep 04, 2016 7:02 pm
Jim, no problem.
Ralf, I did modify socket constructor as you suggested and you were right, it worked.
On top of that, I did modify SSL wrapper:
s = ussl.wrap_socket(s, keyfile=None, certfile=None, server_side=False, cert_reqs=ussl.CERT_REQUIRED, ca_certs='/flash/cert/ca.pem')
The problem now is that it seems that my SSL client does not validate server's certificate - I am able to successfully perform GET request also with incorrect CA certificate.
danielm
Post by danielm » Sun Sep 04, 2016 7:17 pm
Maybe it has something to do with server_side parameter set to False. However setting it to True throws this error:
ValueError: invalid argument(s) value
jgmdavies
Post by jgmdavies » Mon Sep 05, 2016 1:34 pm
@ubiq_01
Hi Ralf,
Many thanks for the tip about
in urequests.py. I can now use HTTPS and POST to services like ThingSpeak, which was failing before with an empty response from the server (leading to "wrong number of values to unpack' errors in urequests.py).
I ended up with:
	if proto == "https:":
		s = usocket.socket(usocket.AF_INET, usocket.SOCK_STREAM, usocket.IPPROTO_SEC)
Best,
Jim
danielm
Post by danielm » Mon Sep 05, 2016 3:55 pm
Jim, did you also test server certificate validation with locally stored CA certificate?
