Failsafe WLAN script
quantalume
Post by quantalume » Wed Sep 14, 2016 6:55 pm
I'm trying to come up with a script that will attempt to connect to the local wireless router in station mode but fall back to access point if unsuccessful. Here is what I have:
# main.py -- put your code here!
from network import WLAN
ssid = 'xxxxx'
auth = (WLAN.WPA2, 'xxxxxxxx')
wlan=WLAN(mode=WLAN.STA)
wlan.antenna(WLAN.EXT_ANT)
wlan.connect(ssid=ssid, auth=auth, timeout=30000)
secs = 0
while (not wlan.isconnected() and secs < 30):
    time.sleep(1)
    secs += 1
if secs == 30:
    wlan.init(mode=WLAN.AP, ssid='wipy-wlan', auth=(WLAN.WPA2,'www.wipy.io'), channel=7, antenna=WLAN.EXT_ANT)
    execfile('thingspeak.py')
When the configured router is absent, the WiPy does not go into access point mode (it never appears in lists of local access points). Any idea why my script is failing? Thanks.
