NEW: WiPy 2.0 - shipping 10 Oct 2016
Online
Re: NEW: WiPy 2.0 - shipping 10 Oct 2016
Post by Roberthh » Tue Sep 20, 2016 5:50 am
With just the board, I would expect the usual situation: between 10m and 100m, depending on the crab that is between transmitter and receiver.
There are some challenges on how far WiFi can reach, but that was in in plain air, with special antennas (see e.g. https://www.wired.com/2007/06/w_wifi_record_2/). And a lot of interesting reading in the net.
Post by pythoncoder » Tue Sep 20, 2016 6:24 am
Indeed, I have seen such reports before. But look at his aerials!
The claim of 1KM "out of the box" is so radical that I very much want to know the test conditions. The difference between 100M and 1KM is 20dB in link budget which doesn't sound much if you say it quickly ;) But it means a factor of 100 in terms of receiver sensitivity; you can't multiply the transmitter power by 100 a) for legal reasons and b) because you can't change the AP at the other end of the link.
Up to now the only way you can get a 20dB improvement in link budget is by using directional antennas which is inconvenient.
So I really want the developers to tell us how this is achieved: it's seriously difficult while maintaining standards compliance.
Post by deshipu » Tue Sep 20, 2016 9:13 am
If we are picking nits, I'd like to direct your attention to the fact, that they didn't write "1km" (kilo-meter), as you seem to be interpreting this. They wrote "1KM". What unit is "KM" I have no idea, but it may as well be that 1KM is equal about 100m, and then everything is right. ;-)
Post by deshipu » Tue Sep 20, 2016 9:19 am
I know, they specified it in Karat-Molars!
fpp
Post by fpp » Tue Sep 20, 2016 9:33 am
Not really, as it would also mean that we are all living in different spacetime references...
My bet is on KM = kilo milimeters :-)
Post by deshipu » Tue Sep 20, 2016 9:38 am
It's a capital K, though, so 1024 millimeters?
kfricke
Post by kfricke » Tue Sep 20, 2016 10:46 am
They are from Amsterdam, Netherlands... they got neither mountains nor hills... so no real sense for range!
bmarkus
Post by bmarkus » Tue Sep 20, 2016 4:29 pm
Sorry for being off topic, just want to comment LoRa. Personal experience is that we can track small private airplane with LoRa. 50km is reliable and stable, getting cca. -4 dB S/N ratio while system limit is around -15dB using a small 0 dB gain stick antenna inside of cockpit. Changing antenna to a cca. 3dB gain and installing tracker outside would make it better. Why only 50km? Because it was the biggest distance during test flight airplane made :) In larger distance flight height can be an issue due to distance to horizon.
Send me a PM if you need details.
HAM radio call: HA5DI (Béla)
Post by pythoncoder » Wed Sep 21, 2016 6:41 am
@bmarkus I've read a number of accounts of long range communication using LoRa. IIRC the spread spectrum modulation method achieves a 20dB improvement in link budget offering an immediate improvement unavailable to WiFi. While LoRa is carrier frequency agnostic, I gather most physical realisations work at 433, 860 or 916MHz frequencies offering further range improvements especially in urban environments.
I think it's an exciting technology, especially if it's deployed by enthusiasts to provide free town and city wide low bandwidth IOT internet access https://www.thethingsnetwork.org/.
bmarkus
Post by bmarkus » Wed Sep 21, 2016 7:32 am
pythoncoder wrote:@bmarkus I've read a number of accounts of long range communication using LoRa. IIRC the spread spectrum modulation method achieves a 20dB improvement in link budget offering an immediate improvement unavailable to WiFi. While LoRa is carrier frequency agnostic, I gather most physical realisations work at 433, 860 or 916MHz frequencies offering further range improvements especially in urban environments.
In Europe 99.9% of networks are on 868MHz. Right, your end device must be registered in a network which can be either a public service or your own network. You can register a small private network at https://loriot.io free for 1 gateway and 10 end devices. Good point is that free networks provide roaming for others. Also, large network operators may decide to offer roaming. For example Budapest and surroundings are covered by independent networks with roaming, and I see roaming in e.g. Linz and Prague for my devices. It is great!
For a gateway you need a Raspberry Pi and a radio board offered by several vendors. So it is not so difficult to start.
