SyntaxError: invalid micropython decorator
danielm
Post by danielm » Tue Oct 11, 2016 8:37 pm
When trying @micropython.native or @micropython.viper decorator on MicroPython v1.8.4-54-gec078af-dirty on 2016-09-22; WiPy with CC3200.
Do I have to enable it manually somewhere before building MP?
Re: SyntaxError: invalid micropython decorator
Post by dhylands » Tue Oct 11, 2016 8:45 pm
@micropython.native and @micropython.viper both require MICROPY_EMIT_NATIVE.
https://github.com/micropython/micropyt ... #L757-L762
It looks like EMIT_NATIVE is defined here:
https://github.com/micropython/micropyt ... fig.h#L291
and the wipy (cc3200) has those disabled:
https://github.com/micropython/micropyt ... .h#L41-L42
danielm
Post by danielm » Tue Oct 11, 2016 9:01 pm
Thanks Dave, I will rebuild tomorrow and check if it works.
Could you please suggest some typical test function on which I should observe improvement when defined with @micropython.native or @micropython.viper decorators?
Post by dhylands » Tue Oct 11, 2016 9:11 pm
I've not really used either, but there is some discussion about it here:
http://docs.micropython.org/en/latest/p ... de-emitter
with at least a viper example.
danielm
Post by danielm » Wed Oct 12, 2016 6:20 pm
I was not able to build MP with MICROPY_EMIT_THUMB and MICROPY_EMIT_INLINE_THUMB set to (1)
CC ../py/compile.c
../py/compile.c: In function 'compile_built_in_decorator':
../py/compile.c:759:24: error: 'MP_QSTR_native' undeclared (first use in this function)
     } else if (attr == MP_QSTR_native) {
../py/compile.c:759:24: note: each undeclared identifier is reported only once for each function it appears in
../py/compile.c:761:24: error: 'MP_QSTR_viper' undeclared (first use in this function)
     } else if (attr == MP_QSTR_viper) {
../py/compile.c:765:24: error: 'MP_QSTR_asm_thumb' undeclared (first use in this function)
     } else if (attr == MP_QSTR_asm_thumb) {
../py/compile.c: In function 'compile_scope_inline_asm':
../py/compile.c:3147:22: error: 'MP_QSTR_uint' undeclared (first use in this function)
                 case MP_QSTR_uint: type_sig = MP_NATIVE_TYPE_UINT; break;
../py/compile.c:3196:19: error: 'MP_QSTR_label' undeclared (first use in this function)
         if (op == MP_QSTR_label) {
../py/compile.c:3208:26: error: 'MP_QSTR_align' undeclared (first use in this function)
         } else if (op == MP_QSTR_align) {
../py/compile.c:3216:26: error: 'MP_QSTR_data' undeclared (first use in this function)
         } else if (op == MP_QSTR_data) {
make: *** [build/WIPY/release/py/compile.o] Error 1
@danicampora - is there a way how to make it work?
Post by dhylands » Wed Oct 12, 2016 6:39 pm
You may need to do a clean after enabling those options.
The auto qstr generator seems to not always regenerate qstrs at the right time. Anytime I see any errors related to qstrs, I typically do a clean and then the problem goes away.
danielm
Post by danielm » Wed Oct 12, 2016 8:58 pm
Dave, it helped, thanks a lot!
Decorator @micropython.native increased performance of my function by almost 10%. I am looking for further improvements.
This is my code - its purpose is to render words consisting of letters - each represented by 20-30 X-Y coordinates defined as two-dimensional lists in a dictionary called "alphabet". I also tried array.array instead but it was not faster.
	@micropython.native
	def renderTest(self, text, factor, times):
		count = 0
		data_array = bytearray(2)
		start = time.time()
		for x in range(times):
			for letterIndex in range(len(text)):
				for pointIndex in range(len(alphabet[text[letterIndex]])):
					data=self.currentX+factor*alphabet[text[letterIndex]][pointIndex][1] + 12288
					data_array[1],data_array[0] = data.to_bytes(2)
					self.spiNSS.value(0)
					self.spiWrite(data_array)
					self.spiNSS.value(1)
					data=self.currentY+factor*alphabet[text[letterIndex]][pointIndex][0] + 45056
					count+=1
				self.currentY+=factor*18
			self.currentY = 0
		print(time.time()-start)
		print(count)
I am manipulating with CS/NSS pin manualy. If this operation would not be required performance could be increased by approx. 10%. However that would require to implement CS toggling on C module level as it was discussed several months ago in another thread.
Is there any faster way how to perform int to (2)byte conversion in reversed order?
Could SPI.write() and Pin.value() be performed with @micropython.viper decorator?
EDIT: I just discovered that following two calculations are consuming 50% of the runtime:
Maybe I could put them in separate function with @micropython.viper decorator?
Post by pythoncoder » Thu Oct 13, 2016 6:26 am
Looking at the innermost loop you're doing repeated lookups which could be cached, something along these lines
for pointIndex, atli in enumerate(alphabet[text[letterIndex]]):
    atli_pi = atli[pointIndex]
    data=self.currentX + factor * atl_pi[1] + 12288
    data_array[1], data_array[0] = data.to_bytes(2)
    data=self.currentY + factor * atli_pi[0] + 45056
    count+=1
I suspect the first two lines can be reduced to one but I can't get my head round it at 7:20am...
danielm
Post by danielm » Wed Oct 19, 2016 4:16 pm
@pythoncoder, I wanted to implement your solution, however enumerate() probably does not work with list of lists as expected:
>>> alphabet["A"]
[[0, 0], [1, 4], [2, 8], [3, 12], [4, 16], [5, 20], [6, 24], [7, 28], [8, 32], [9, 28], [10, 24], [11, 20], [12, 16], [13, 12], [10, 12], [6, 12], [13, 12], [14, 8], [15, 4], [16, 0]]
>>> for pointIndex, atli in enumerate(alphabet["A"]):
...     print(atli[pointIndex])
0
4
  File "<stdin>", line 2, in <module>
IndexError: index out of range
deshipu
Post by deshipu » Wed Oct 19, 2016 6:43 pm
"atli" are the individual elements there, and since they only have 2 items each, it's natural you get IndexError.
