WiPy2 - NotImplementedError: byte code not implemented
Posted: Sun Jan 15, 2017 6:01 am
using sockets, I have created a simple web server, with a single connection.
This connection has a javascript setInterval() that every 15 seconds makes the same call to the webserver.
Problem is the server is randomly crashing with:
[code]
p��?", line 1, in P2 "93"}�-@?���? /@?��������(�@?��?P��?�@?@��?192.168.0.88(�@?0��?}��@?��
[/code]
I'm not sure what this "byte code not implemented" means, but as mentioned, the calls every 15 seconds are identical so I don't know why some of them are causing the system to crash ?
[code]
[/code]
