Looking for terminator in data drom UART
michalt38
Post by michalt38 » Thu Mar 23, 2017 9:08 pm
I need to catch a terminator \r in data I receive from UART and I've got this code:
[code]
data = ""
bytes = uart.read()
if bytes is not None:
idx = str(bytes).find("'", 2)
data += str(bytes)[2:idx]
print(data[len(data)-2:])
if data.find("\r") != -1:
print("Here\r\n")
[/code]
But data.find("\r") always returns -1 even when data contains \r. How to solve this problem?
Re: Looking for terminator in data drom UART
Post by dhylands » Fri Mar 24, 2017 12:05 am
I suspect that you're being tripped up by the difference between strings and bytestrings.
The UART returns bytestrings, so you should be searching for b'\r'
MicroPython v1.8.7-201-ga34ff35 on 2017-02-07; linux version
>>> data = b'abc\rdef'
>>> data.find('\r')
TypeError: can't convert 'str' object to str implicitly
>>> data.find(b'\r')
3
