Import precompiled code into wipy 2.0
Arkaik
Post by Arkaik » Tue May 02, 2017 3:16 pm
Hi everyone,
I'm currently trying to import precompiled code but it always fails.
I followed this topics but the repository seems to have changed a bit and I think the procedure isn't good anymore.
viewtopic.php?f=11&t=2326
viewtopic.php?f=3&t=2334&p=13322&hilit= ... led#p13322
What I did is first to clone the micropython-esp32 repository at https://github.com/micropython/micropython-esp32 to my computer.
Then I built mpy-cross and precompile my module.
As the line #define MICROPY_PERSISTENT_CODE_LOAD (1) already exists in micropython/cc3200/mpconfigport.h and py/emitglue.c doesn't contains 400 lines anymore (looks like it changed a lot) I suppose I don't need to rebuild the firmware anymore. Am I right?
Whatever when I try to load my precompiled module from flash it's never found by python.
I would like to know what I am dooing wrong. I have to admit that I feel a little lost with all the repos and different boards that exist.
So should I rebuild the firmware and flash it to my board or it's not necessary?
Am I using the good repository when I compile with mpy-cross?
I also tried to compile with the -mcache-lookup-bc option but I obtain the same result, is there more option I'm missing?
I will certainly have other questions as I'm a pure noob in micropython but I think I begin to understand how it works.
I hope someone will help me because I'm stuck with it for quite a long time ^^.
Thank you in advance and sorry if my english is not perfect ;)
Online
Re: Import precompiled code into wipy 2.0
Post by Roberthh » Wed May 03, 2017 6:00 am
So you are trying to use the esp32 build of micropython.org on your wipy 2.0? That should work. By mistake, I did that for a Lopy, and it worked too, even if that was not the intention. The opposite works too, including execution of pre-compiled files.
The esp32 port of micropython.org has the support for pre-compiled files already built-in, and I tried that it works.
You have to use mpy-cross from the same tree ans the esp32 code, since the mpy-cross versions differ.
You can also put your Python scripts into esp/modules and build the firmware, creating frozen bytecode. I have done that and it works.
Arkaik
Post by Arkaik » Wed May 03, 2017 9:50 am
Hi, thank you for the quick answer.
I tried both solutions without success.
As you said the support of pre-compiled files is already built-in, I tried with the latest firmware (Flashed with the update script given by pycom.io).
After flashing the latest firmware I pre-compiled my module with the mpy-cross tool from esp32 branch to a .mpy file and I upload it to the board into the flash/ folder with ftp.
When I tried to import it from repl, the module is not found.
I can succesfully build the firmware, I built it from the git micropython-esp32 branch as precised in doc.
I flashed it with success after erasing flash but when I boot the board, there was no wipy-wlan-xxxx wifi access point so I can't use it.
Did I miss something?
I included nothing to the firmware for the test purpose and I don't know why I can't see the wifi AP.
I precise that after flashing the custom firmware, the led was not blinking with blue color as it does when using the updater.
Online
Post by Roberthh » Wed May 03, 2017 10:06 am
Which Repository are you using?
a) https://github.com/micropython/micropyt ... sp32/esp32
b) https://github.com/pycom/pycom-micropyt ... ster/esp32
c) https://github.com/pycom/pycom-micropyt ... ster/esp32
In a) precomiled code is supported both for frozen bytecode and .mpy files
in b) frozen bytecode is upported, and procmpiled .mpy files can be added by inserting
into mpconfigport.h
in c) no support for frozen bytecode or precompiled files. This is an obsolete branch.
In any case, you have to use mpy-cross from that branch.
For b) and c), this is the wrong forum. You might get also and mybe better support at https://forum.pycom.io/
Arkaik
Post by Arkaik » Wed May 03, 2017 12:24 pm
I'm using the first repository a) https://github.com/micropython/micropyt ... sp32/esp32
After building and flashing the firmware, I still have no wifi AP.
I precise that I just clone the esp-idf repository but I didn't build any project.
When I boot the board after flashing, the led was enabled with green soft light. After reboot again, no led enabled.
If I boot in bootloader mode G23+GND the led is enabled with high green light.
Does this green light meems something?
If I understood well, the led is supposed to blink blue every 4 sec.
Online
Post by Roberthh » Wed May 03, 2017 8:48 pm
There is a note in readme that if you use that port on wipy, you have to switch the antenna. Look here at the end of the file https://github.com/micropython/micropyt ... /README.md
The LED is only blinking with the pycom.io firmware, choice b) or c).
