WiPy 1.0 filesystem reset
Niallp
Post by Niallp » Sun Mar 11, 2018 7:39 am
Still struggling with my WIPy 1.0 running 1.9.3, it does not appear to be reading the boot.py or main.py scripts on startup. The files appear OK via ftp but were left over from earlier versions so I tried resetting the flash file system.
The recipe as documented doesn't work (http://docs.micropython.org/en/latest/w ... tory-reset,
any other suggestions ?
romeotango
Re: WiPy 1.0 filesystem reset
Post by romeotango » Fri Jan 31, 2020 7:18 am
Had the same problem.
I went back FIRST version of firmware, with the boot options described in docs.
The os.mkfs ("/flash") ist available in this old version.
After that installed the actual version via ftp.
This is for WIPY1!
