REPL via expansion board USB - missing jumpers?
gerwindehaan
Post by gerwindehaan » Sat Oct 10, 2015 8:52 am
I am trying to enable the REPL via UART using the microUSB connector on the expansion board.
I tried to enable the terminal duplication manually when logged in via WiFi, and via boot.py through the following code:
# enable the UART on the USB-to-serial port
import os
uart = UART(0, baudrate=115200)
os.dupterm(uart)
Then, I try to connect from my OSX station using
screen /dev/tty.usbserial-DB00IANO 115200
I noticed people had used this, but no success for me.
Then I noticed people posting images of the expansion board with a bunch of jumpers on it, while mine doesn't come with any jumpers.
Looking at the designs https://github.com/wipy/wipy/tree/maste ... Board-v1.2 it appears JP3A , JP3B, JP3C and JP3D should connect the onboard FTDI serial-to-USB to the UART ports of the WiPy board. This might be the reason I get no tty response.
I don't have any electronics prototyping gear at hand now, but I'm going to scavenge some stuff to test this assumption. Can anyone confirm? Are there other features that can be en/disabled by the jumpers?
danicampora
Re: REPL via expansion board USB - missing jumpers?
Post by danicampora » Sat Oct 10, 2015 11:37 am
Yes, you need the jumpers in place. Sorry that yours was shipped without them...
hugohase
Post by hugohase » Fri Oct 23, 2015 6:27 pm
Hallo, just received wipy from Kickstarter.
MicroPython v1.5-1-ge954604 on 2015-10-21; WiPy with CC3200
Your Example didn't work, only wild character on screen.
By removing Baudrate it works.
I hope this helps.
import os
uart = UART()
os.dupterm(uart)
Mac:
screen /dev/tty.usbserial-DEADBEEF
platforma
Post by platforma » Sat Oct 24, 2015 9:33 pm
@hugohase
You need to set the baudrate when invoking screen from your terminal, I'm not sure what it defaults to otherwise, I've been using picocom for a while now. For example:
screen /dev/tty.usbserial-DEADBEEF 115200
