Hello everyone,
I'm looking for a guide on how to burn micropython on my NUCLEO F401RE in windows 10 os.
Thank you
[NUCLEO-F401RE] burn micropython on NUCLEO-F401RE
Re: [NUCLEO-F401RE] burn micropython on NUCLEO-F401RE
I have the same question. Plus I have a Nucleo STM32F411 board I want to program with MicroPython.
Yes, I'm looking for a simple procedure to upload the MicroPython image in Windows..
For a Nucleo-F411:
It seems that you need to attach a USB connector to PA11 and PA12 (DM/DP) on CN10 pins 12 & 14. Then place a jumper between CN7 pins 5 & 7 to enable boot mode. Then program it using the DFU programmer using the USB connector you just soldered on.
I think these are the same pins with the F401.
A real pain. Anyone else got a better idea?
You can also use the st-link tools (under Windows, Mac or Linux) to flash using the stlink programmer built into the NUCLEO boards.
https://github.com/stlink-org/stlink
I've done this in the past on all 3 platforms, but it's been a while since I did it under Windows, so I don't recall the steps needed.
