[ATSAMD] How to setup SAMD series build environment?
water
Post by water » Mon Apr 26, 2021 8:04 pm
I try to build ATSAMD51 use
make BOARD=MINISAM_M4
, return error below:
mkdir -p build-MINISAM_M4/genhdr
GEN build-MINISAM_M4/genhdr/mpversion.h
GEN build-MINISAM_M4/genhdr/moduledefs.h
GEN build-MINISAM_M4/genhdr/qstr.i.last
In file included from modmachine.c:29:
samd_soc.h:30:10: fatal error: sam.h: No such file or directory
30 | #include "sam.h"
compilation terminated.
File "/home/mc3/pycode/micropython/ports/samd/../../py/makeqstrdefs.py", line 188, in <module>
preprocess()
File "/home/mc3/pycode/micropython/ports/samd/../../py/makeqstrdefs.py", line 62, in preprocess
for output in p.imap(pp(flags), chunks):
File "/usr/lib64/python3.9/multiprocessing/pool.py", line 870, in next
raise value
File "/usr/lib64/python3.9/multiprocessing/pool.py", line 125, in worker
result = (True, func(*args, **kwds))
File "/home/mc3/pycode/micropython/ports/samd/../../py/makeqstrdefs.py", line 46, in run
return subprocess.check_output(args.pp + flags + files)
File "/usr/lib64/python3.9/subprocess.py", line 424, in check_output
return run(*popenargs, stdout=PIPE, timeout=timeout, check=True,
File "/usr/lib64/python3.9/subprocess.py", line 528, in run
raise CalledProcessError(retcode, process.args,
subprocess.CalledProcessError: Command '['arm-none-eabi-gcc', '-E', '-I.', '-I../..', '-Ibuild-MINISAM_M4', '-Iboards/MINISAM_M4', '-I../../lib/cmsis/inc', '-I../../lib/asf4/samd51/include', '-I../../lib/tinyusb/src', '-Wall', '-Werror', '-std=c99', '-nostdlib', '-mthumb', '-mtune=cortex-m4', '-mcpu=cortex-m4', '-mfpu=fpv4-sp-d16', '-mfloat-abi=hard', '-fsingle-precision-constant', '-Wdouble-promotion', '-DMCU_SAMD51', '-D__SAMD51G19A__', '-Os', '-DNDEBUG', '-fdata-sections', '-ffunction-sections', '-DNO_QSTR', '../../py/objsingleton.c', '../../py/objslice.c', '../../py/objstr.c', '../../py/objstrunicode.c', '../../py/objstringio.c', '../../py/objtuple.c', '../../py/objtype.c', '../../py/objzip.c', '../../py/opmethods.c', '../../py/sequence.c', '../../py/stream.c', '../../py/binary.c', '../../py/builtinimport.c', '../../py/builtinevex.c', '../../py/builtinhelp.c', '../../py/modarray.c', '../../py/modbuiltins.c', '../../py/modcollections.c', '../../py/modgc.c', '../../py/modio.c', '../../py/modmath.c', '../../py/modcmath.c', '../../py/modmicropython.c', '../../py/modstruct.c', '../../py/modsys.c', '../../py/moduerrno.c', '../../py/modthread.c', '../../py/vm.c', '../../py/bc.c', '../../py/showbc.c', '../../py/repl.c', '../../py/smallint.c', '../../py/frozenmod.c', '../../extmod/moduasyncio.c', '../../extmod/moductypes.c', '../../extmod/modujson.c', '../../extmod/modure.c', '../../extmod/moduzlib.c', '../../extmod/moduheapq.c', '../../extmod/modutimeq.c', '../../extmod/moduhashlib.c', '../../extmod/moducryptolib.c', '../../extmod/modubinascii.c', '../../extmod/virtpin.c', '../../extmod/machine_mem.c', '../../extmod/machine_pinbase.c', '../../extmod/machine_signal.c', '../../extmod/machine_pulse.c', '../../extmod/machine_i2c.c', '../../extmod/machine_spi.c', '../../extmod/modbluetooth.c', '../../extmod/modussl_axtls.c', '../../extmod/modussl_mbedtls.c', '../../extmod/modurandom.c', '../../extmod/moduselect.c', '../../extmod/moduwebsocket.c', '../../extmod/modwebrepl.c', '../../extmod/modframebuf.c', '../../extmod/vfs.c', '../../extmod/vfs_blockdev.c', '../../extmod/vfs_reader.c', '../../extmod/vfs_posix.c', '../../extmod/vfs_posix_file.c', '../../extmod/vfs_fat.c', '../../extmod/vfs_fat_diskio.c', '../../extmod/vfs_fat_file.c', '../../extmod/vfs_lfs.c', '../../extmod/utime_mphal.c', '../../extmod/uos_dupterm.c', '../../lib/embed/abort_.c', '../../lib/utils/printf.c', 'build-MINISAM_M4/genhdr/moduledefs.h', 'modutime.c', 'modmachine.c', 'boards/MINISAM_M4/mpconfigboard.h', '../../py/mpconfig.h', 'mpconfigport.h']' returned non-zero exit status 1.
make: *** [../../py/mkrules.mk:105: build-MINISAM_M4/genhdr/qstr.i.last] Error 1
make: *** Deleting file 'build-MINISAM_M4/genhdr/qstr.i.last'
Which software need to install and setup to build ATSAMD series? Is it have simple instruction?
scruss
Re: How to setup SAMD series build environment?
Post by scruss » Mon Apr 26, 2021 8:50 pm
Looks like you forgot to
make submodules
from the ports/samd folder.
There's a bit about building here: viewtopic.php?f=12&t=7965&p=56716#p56711
Note that the SAMD ports have no hardware access yet, so they're not very useful.
water
Post by water » Mon Apr 26, 2021 9:55 pm
make submodules
from ports/samd
Updating submodules: lib/asf4 lib/tinyusb
make BOARD=ADAFRUIT_ITSYBITSY_M4_EXPRESS
The error above appear still.
But I success build some STM32 at same environment.
scruss
Post by scruss » Tue Apr 27, 2021 1:47 am
I just did exactly the same, and was successful:
mkdir -p build-ADAFRUIT_ITSYBITSY_M4_EXPRESS/genhdr
GEN build-ADAFRUIT_ITSYBITSY_M4_EXPRESS/genhdr/mpversion.h
GEN build-ADAFRUIT_ITSYBITSY_M4_EXPRESS/genhdr/moduledefs.h
GEN build-ADAFRUIT_ITSYBITSY_M4_EXPRESS/genhdr/qstr.i.last
GEN build-ADAFRUIT_ITSYBITSY_M4_EXPRESS/genhdr/qstr.split
GEN build-ADAFRUIT_ITSYBITSY_M4_EXPRESS/genhdr/qstrdefs.collected.h
QSTR updated
CC ../../lib/tinyusb/src/device/usbd_control.c
CC ../../lib/tinyusb/src/portable/microchip/samd/dcd_samd.c
CC ../../lib/tinyusb/src/tusb.c
CC ../../lib/utils/gchelper_native.c
CC ../../lib/utils/pyexec.c
CC ../../lib/utils/stdout_helpers.c
AS ../../lib/utils/gchelper_m3.s
LINK build-ADAFRUIT_ITSYBITSY_M4_EXPRESS/firmware.elf
   text	   data	    bss	    dec	    hex	filename
 101832	     24	   1328	 103184	  19310	build-ADAFRUIT_ITSYBITSY_M4_EXPRESS/firmware.elf
Converting to uf2, output size: 203776, start address: 0x4000
Wrote 203776 bytes to build-ADAFRUIT_ITSYBITSY_M4_EXPRESS/firmware.uf2.
If it's giving the same error, are you missing:
../../lib/asf4/samd51/include/sam.h
../../lib/asf4/samd21/include/sam.h
water
Post by water » Tue Apr 27, 2021 2:49 pm
Solved, lib/asf4 folder empty, execute
git submodule update --init lib/asf4
build pass, but I execute
git submodule update --init --recursive
from micropython root folder before, why lib/asf4 folder is empty?
scruss
Post by scruss » Tue Apr 27, 2021 3:47 pm
No real idea, sorry. Until recently, issuing --recursive would tend to pull in multiple copies of each library for each port. This took far too long.
Good luck working on the SAMD chips. It's kind of annoying that Adafruit's Circuitpython forked off with all the SAMD code coming after.
Post by dhylands » Tue Apr 27, 2021 4:49 pm
The lib/asf4 directory isn't empty for me.
You might want to try starting over with a fresh micropython tree. If I do the following:
git clone https://github.com/micropython/micropython micropython2
cd micropython2
then I wind up with the following in lib/asf4:
$ ls lib/asf4/
README.md  samd21/    samd51/    tools/
