tinyPico - OSError: [Errno 19] ENODEV
hybotics
Post by hybotics » Wed Jul 14, 2021 4:32 pm
I have a tinyPico with Micropython and am getting the dreaded Error 19. There is nothing connected to the tinyPico and I have already erased flash and reflashed Micropython to the board. This did not have any effect. I have attached the complete library I am working with now - hybotics_ht16k33 in case the other files are needed.
I am getting:
MPY: soft reboot
  File "main.py", line 20, in <module>
  File "/lib/hybotics_ht16k33/ht16k33.py", line 16, in __init__
  File "/lib/hybotics_ht16k33/ht16k33.py", line 22, in _write_cmd
MicroPython v1.16 on 2021-06-23; TinyPICO with ESP32-PICO-D4
If I knew more about what the error is trying to tell me, I might have a better chance of figuring this out and fixing it. This is to be a port of Adafruit's ht16k33 library.
Am I missing something?
8-Dale
hybotics_ht16k33.zip
(3.51 KiB) Downloaded 1730 times
Re: tinyPico - OSError: [Errno 19] ENODEV
Post by dhylands » Fri Jul 16, 2021 1:18 am
It sounds like the code is trying to communicate with an external device and that device isn't connected. You did say that nothing was connected right?
