*Full initial disclosure - I am quite new to the coding community and this is my first time setting up an MCU, so please bear with me*
I am attempting to set up an STM32F411RE with micropython and to be able to use the board with PuTTY for an easier coding experience in the future. I have successfully downloaded the micropython .dfu file for the F411re board from the micropython website and uploaded to the board using DFU. At this point however I am not quite sure how to proceed to get putty to successfully communicate with the board. I have the com port in the putty terminal matching with the corresponding com port on the device manager, but no response when I open up the Putty terminal.
Any help would be greatly appreciated!
[Nucleo- F411RE] Setting Up To Work With Putty
Re: [Nucleo- F411RE] Setting Up To Work With Putty
Putty must be set to 115200 Baud, 8 Data bit, 1 stop bit, no parity, no flow control (!).
I applied all of those parameters, but there still appears to be no communication occurring between the putty and nucleo :/
Can you confirm the steps you used to flash the DFU file? Just to ensure that this part definitely succeeded.mat_wey wrote: ↑Mon Jul 19, 2021 7:18 pmI am attempting to set up an STM32F411RE with micropython and to be able to use the board with PuTTY for an easier coding experience in the future. I have successfully downloaded the micropython .dfu file for the F411re board from the micropython website and uploaded to the board using DFU.
The 411 nucleo is a bit annoying because it doesn't have a USB interface available to the main MCU so the regular DFU flashing methods aren't available. You must program it via the ST-Link USB interface.
