[Nucleo-F767ZI] USB Mass storage content does not update
PieyeGmbH
Post by PieyeGmbH » Sun Aug 22, 2021 4:38 pm
Hy,
I am using an Nucleo-F767ZI with an SD card extension. Everything works smoothly, I run code from flash and use sd card as log memory, which is written by my python code and can be read out USB mass storage access as external drive from PC.
but the drive content of the USB mass storage does only update when I reset the python board.
I tried to .flush() the file after writing to it, I close the file with .close(), and I see the file and the content in python. But it does not show up in the mass storage device.
To replicate:
f=open("/sd/log.txt", "wb")
testInt=0
while(testInt<100):
  f.write("%i\n"%testInt)
  testInt+=1
f.flush()
f.close()
os.listdir()
['System Volume Information', 'log.txt']
PieyeGmbH
Re: [Nucleo-F767ZI] USB Mass storage content does not update
Post by PieyeGmbH » Wed Sep 22, 2021 10:34 pm
Apparently, there is no reason and no fix. I live with a workaround: disabling and reenabling USB does the trick.
     logFile.write("\n".encode())
     logFile.flush()
     logFile.close()
     logAnnotation=None
     # unmount and remount sd card to update USB drive
     pyb.usb_mode(None)
     #pyb.usb_mode('VCP+MSC',msc=(pyb.SDCard(), pyb.Flash()))  # for development: map both file systems
     pyb.usb_mode('VCP+MSC',msc=[pyb.SDCard()])
Post by Roberthh » Thu Sep 23, 2021 5:51 am
That is a behavior of the PC. The PC is not aware of the python device updating to the mass storage as well. And so it gets bad.
