RSHELL and OpenMV?
Posted: Sat Jan 08, 2022 3:44 am
There was a thread from a few years ago ( viewtopic.php?t=2737 ) noting that RSHELL wasn't working with OpenMV. Was that ever fixed? I've searched the OpenMV, RSHELL, and MicroPython sites/repos and come up empty-handed.
I'm currently testing an OpenMV H7 R1 board. I'm running RSHELL version 0.0.31, Python 3.9.9 (but I'm flexible if that's an issue), and the OpenMV module reports the following (it came preloaded like this from my client, I didn't build it myself):
I can connect to it using Thonny and serial port. If I try RSHELL, it either hangs at the "Trying to connect to REPL" prompt, or I've gotten the below informational dump a few times. Any idea what's up?
I'm not at all familiar with OpenMV, and have naively assumed it should behave like MP. Maybe I'm wrong. Should I even expect RSHELL to work with OpenMV? Or is there some known incompatibility with RSHELL of which I'm blissfully unaware?
-Chris
MicroPython: v1.15-r57 OpenMV: v4.1.1 HAL: v1.9.0 BOARD: OPENMV4-STM32H743
-Chris
(.venv) rclott@herman openmv$ rshell -d -e nvim -p /dev/cu.usbmodem365E376830381 -b 115200
Debug = True
Port = /dev/cu.usbmodem365E376830381
Baud = 115200
User = micro
Password = python
Wait = 0
List = 0
nocolor = 0
ascii = 0
Timing = 0
Quiet = 0
BUFFER_SIZE = 512
Cmd = []
Using buffer-size of 32
Connecting to /dev/cu.usbmodem365E376830381 (buffer-size 32)...
Trying to connect to REPL connected
Retrieving sysname ... ----- About to send 205 bytes of code to the pyboard -----
def sysname():
import os
return repr(os.uname().sysname)
except:
return repr('unknown')
output = sysname()
if output is None:
print("None")
print(output)
b'OK\r\nraw REPL; CTRL-B to exit\r\n>'
File "/Users/rclott/root/files/projs/novac/projs/openmv/.venv/lib/python3.9/site-packages/rshell/main.py", line 1381, in connect
ip_address = socket.gethostbyname(port)
socket.gaierror: [Errno 8] nodename nor servname provided, or not known
