mode [ON/OFF]
NicoleN
mode [ON/OFF]
Post by NicoleN » Fri Nov 27, 2015 8:05 am
startup value: mode = False
if mode == False:
    mode = True
    do something
    mode = False
    do something else
This works up to 10 times, then:
RuntimeError: maximum recursion depth exceeded
any idea how to fix it?
Re: mode [ON/OFF]
Post by dhylands » Fri Nov 27, 2015 8:14 am
You'd need to provide more information.
You must have something like a function foo that calls itself, or calls something else which calls itself:
def foo():
    do stuff
    something()
def something():
    do stuff
    foo()
NicoleN
Re: mode [ON/OFF]
Post by NicoleN » Fri Nov 27, 2015 8:58 am
mode_1 = False
def mode1():
    execfile('/flash/mode1.py')
/flash/mode1.py:
if mode_1 == True:
    mode_1 = False
    pin1.low()
    execfile('/flash/main.py')
    mode_1 = True
def do_stuff():
    pin1.high()
    if BT.any() == True:
        do_stuff()
mode1() -> pin ON
mode1() -> pin OFF
mode1() -> pin ON
mode1() -> pin OFF
mode1() -> pin ON
mode1() -> pin OFF
mode1() -> RuntimeError: maximum recursion depth exceeded
danicampora
Re: mode [ON/OFF]
Post by danicampora » Fri Nov 27, 2015 9:23 am
Ok, maybe I am getting it wrong, but it looks that your main.py calls mode1.py which then calls main.py again, is that correct? If so then you have a recursion there, what's the intention....?
NicoleN
Re: mode [ON/OFF]
Post by NicoleN » Fri Nov 27, 2015 9:56 am
that is correct. Thanks, I ll try to fix it
Re: mode [ON/OFF]
Post by dhylands » Fri Nov 27, 2015 6:24 pm
When main1.py gets to the end execution will resume in main.py after the execfile call.
Alternatively you could put a try/except around the execfile call and have main1.py raise an error to get back to main.py
