Porting to STM32L476Discovery/LimiFrog
badi
Re: Porting to STM32L476Discovery/LimiFrog
Post by badi » Wed Mar 02, 2016 10:48 am
CDC and MSC is working
- REPL is working now.
- The kit appears as USB memory stick on my PC and the Flash memory is persistent.
DMA on DAC must be resolved and therfore the repo does not compile on other platforms using DAC.
badi
badi
Post by badi » Thu Mar 03, 2016 8:11 am
Compiles with working DAC on all STM build targets even my audio shield for pyboard V1.0 works.
After some tests I'll try to push it to main repo.
badi
jgriessen
Post by jgriessen » Fri Mar 04, 2016 12:58 am
Congrats on getting your port debugged!
photoacoustic
Post by photoacoustic » Fri Mar 04, 2016 11:19 pm
Thanks for the great work
badi
Post by badi » Sat Mar 05, 2016 7:59 am
It is a little bit early .. first I have to get it into the main repo and there are some changes which are quite big.
BTW I am still hunting bugs...
badi
badi
Post by badi » Tue Mar 08, 2016 10:23 pm
I hope I just squashed the last bug .. but someone said the last bug is never found ;-( ...
badi
badi
Post by badi » Wed Mar 23, 2016 10:09 pm
I just entered the last PR in a series (#1888, #1890, #1903, #1904, #1916, #1917, #1918, #1919, #1920, #1921, #1922, #1924, #1925, #1937) to support stm32l476Disco
badi
badi
Post by badi » Wed Mar 30, 2016 8:01 am
I added basic support for building LIMIFROG and deploy over stlinkk to my repo at
https://github.com/tobbad/micropython/t ... ntegration
If you have a STLINK at hand (is on any discovery board) you can deploy the binary with:
`make BOARD=LIMIFROG deploy2b`
I need this special target (defined in `mpconfigboard.mk`) as the flash on LimiFrog is just 512 so the `.text` area (this is were firmware1.bin has to be stored) starts @ 0x080008800.
badi
marfis
Post by marfis » Thu Mar 31, 2016 9:31 pm
Did you manage to support the internal OpAmps as well?
badi
Post by badi » Fri Apr 01, 2016 1:54 pm
It was not the aim of this series of PR to support all feature on this new L4 series - so I kept the changes to micropython stmhal code to an absolute minimum. In my opinion further extension can later be added. I think these PRs should be a door opener for others to contribute code.
badi
