STM32F411E Discovery - How to power and access the REPL
Posted: Sun Apr 17, 2016 7:35 am
by cakestone
Hi everyone,
after using the pyboard I want to use the F411E Discovery now.
What I have done sofar:
- downloaded the STM32F4 Discovery board .dfu firmware from micropython.org
- flashed the firmware with DfuSe Demo, seems OK, at least the built-in program stopped working
Now I would like to access the REPL but can't get to a serial port, neither through USB-OTG nor ST-LINK-USB.
How am I supposed to
- power the board -- through one of the USBs or external power supply?
- connect to REPL -- via one of the USBs or one of the UARTs (via a USB-UART converter)?
Thanks.
Re: STM32F411E Discovery - How to power and access the REPL
Posted: Sun Apr 17, 2016 6:20 pm
by dhylands
You mean Discovery (the green board) and not Nucleo (the white board).
The discovery looks like this:
http://www.st.com/web/catalog/tools/FM1 ... 8/PF260946
You can power it using the mini-USB jack or by providing 5V (as described in the User Manual in Section 4.2 (there is a link to the User Manual on the page mentioned above).
You can also power it using the Micro-USB connector on the bottom of the board. In this case you need to provide a jumper from PA9 to 5V (similar to the technique used with the 407 discovery:
https://github.com/micropython/micropyt ... -Discovery
Otherwise you should get the REPL on the Micro-USB jack. I don't have a 411 Discovery myself, so I can't offer much else.
Posted: Sun Apr 17, 2016 7:57 pm
by cakestone
Yes, I mean the green Discovery, besides STM32F411E labeled also MB1115B.
Is that the board the firmware at
http://micropython.org/resources/firmwa ... 1480fb.dfu is meant for? Or is it for F407?
Otherwise powering via USB-OTG works with PA9 wired to 5V, as you suggested, but the USB doesn't appear as a serial port.
Posted: Mon Apr 18, 2016 12:03 am
by dhylands
The original discovery is called STM32F4DISC and its for a 407. Later on when STM released more discovery boards it included the chip number in the board name. So the 411 discovery is called the STM32F411DISC. You need to build the firmware yourself. There isn't any prebuilt firmware available.
If you're running the SM32F4DISC firmware, then I'm not surprised (since its for the wrong processor).
