This is idea ...
I get Espruino pico board + arduino headers and this is crazy MIX
Because exist native DFU Micropython port for Espruino PICO you can run BOTH on same board of course you can program native STM32 code... and maybe exist STM32F4 Arduino core or .NET ????
Now in credit card shape
...There is lot of space for extra buttons ... headers .... etc ... oled, rtc, cr2032 battery RGB led, encoder, rf module or just simple card ??
https://hackaday.io/project/12222-ema-h ... on-arduino
EMA = Hybrid Espruino Pico + Micropython + Arduino
- emabrd.png (16.19 KiB) Viewed 4472 times
Re: EMA = Hybrid Espruino Pico + Micropython + Arduino
You'll probably want a reset button, and maybe a USER button (used to reset the filesystem).
You may want to look at the Netduino Plus 2: http://www.netduino.com/netduinoplus2/specs.htm
It uses a 405, but you may want to try and maintain pin compatability.
For a big board like that I'd definitely want the option for a USB connector rather than the plug directly into a USB (like the Espruino).
Having an sdcard would be a big plus, even it was just a 1 line SPI based one like on the Netduino.
The button that you do have seems to be labelled with both BOOT0 and BOOT1. I'm assuming it would be BOOT0?
You might also want to put some Grove connectors since you've got space.
this is very coarse layout ....
I want use stm32f401cdu6 same as is in espruino pico because exists precompiled dfu files.
Personally, if I was going to stick with the 401, I would pick the STM32F401RET6 because it has more flash.
The images created for the Espruino will still work, but the Espruino Pico flash is very close to being full. Actually, it looks like it has already overflowed.
I just built using the latest and I see: The .text section being 0x400d8 means that 0xd8 bytes won't fit.
The Espruino Pico only has 384K flash, where the STM32F401RET6 has 512K flash.
2004 >arm-none-eabi-objdump -h build-ESPRUINO_PICO/firmware.elf
build-ESPRUINO_PICO/firmware.elf: file format elf32-littlearm
Sections:
Idx Name Size VMA LMA File off Algn
0 .isr_vector 0000272c 08000000 08000000 00010000 2**2
CONTENTS, ALLOC, LOAD, READONLY, CODE
1 .text 000400d8 08020000 08020000 00020000 2**2
2 .data 00000108 20000000 080600d8 00070000 2**2
CONTENTS, ALLOC, LOAD, DATA
3 .bss 00006428 20000108 080601e0 00070108 2**2
ALLOC
4 .heap 00004000 20006530 080601e0 00076530 2**0
ALLOC
5 .stack 00000800 2000a530 080601e0 0007a530 2**0
ALLOC
6 .ARM.attributes 00000035 00000000 00000000 00070108 2**0
CONTENTS, READONLY
7 .comment 000000de 00000000 00000000 0007013d 2**0
CONTENTS, READONLY
