Page 2 of 3
Re: VCC-GND STM32F407VET6 dev board
Posted: Thu Mar 09, 2017 1:00 am
by mcauser
Board definition moved here:
https://github.com/mcauser/VCC_GND_F407
Using @dhylands approach, with separate git repos per board, and clone them into stmhal/boards when needed
https://github.com/dhylands/wiki/wiki/M ... oard-files
Posted: Mon Apr 03, 2017 5:33 am
by Javid
Hi. Need some advice. I bought one of this boards and confused with led light.
I used code from vcc-gnd.taobao.com for led it works. But what if i want to use cubemx?
Used Cubemx and then used simple code but it doesnt work.
HAL_GPIO_TogglePin(GPIOB, GPIO_PIN_9);
HAL_Delay(500);
Does this board work with Hal drivers? May be you can add example with hal driver?
Posted: Mon Apr 03, 2017 8:23 pm
by dhylands
The board works with the HAL, since micropython uses the HAL.
Did you also configure the pin as an output? and enable the clock for Port B?
Do you have a complete code example?
I have a small repository here: https://github.com/dhylands/stm32-test and if you check that out and do:
make BOARD=VCC-GND-F407
then that builds a small app that flashes the BLUE Led on the board (and uses the HAL)
Posted: Fri Jul 14, 2017 5:46 am
by mhwang1973
I set the board to DFU mode , and download the flash using:
$make BOARD=VCC_GND_F407 deploy
It worked in MACos, but met a driver trouble in Win7 X64. It can be read as a mass strorage, but the VCP cannot work.
What is the problem?
Posted: Wed Aug 02, 2017 9:17 am
by Turbinenreiter
I just ordered one. And I feel a bit dirty.
Can we have a way to throw money at the project other than buying Pyboards? A donate-button would be cool, but also something that can be billed - companies need billing.
Posted: Wed Aug 02, 2017 11:58 am
by deshipu
Turbinenreiter wrote: Can we have a way to throw money at the project other than buying Pyboards? A donate-button would be cool, but also something that can be billed - companies need billing.
IIRC you can buy stickers to support the project.
Posted: Wed Aug 02, 2017 5:43 pm
by Turbinenreiter
From Adafruit, shipping them from New York to Munich :lol:
Great option to add to my next Adafruit order.
Posted: Sat Feb 24, 2018 11:07 pm
by KevinA
[quote=loboris post_id=17496 time=1485367486 user_id=923]
There are even better boards with [b]STM32F407ZET6[/b] for ~13-17 US$ with optional external [b]SDRAM[/b] (1 MByte IS62WV51216BLL, ~2-5 US$)
http://www.ebay.com/sch/i.html?_from=R4 ... T6&_sop=15
https://www.aliexpress.com/w/wholesale- ... 0125100625
https://www.aliexpress.com/w/wholesale- ... 0125100822
I'm not shure if MicroPython suppports external SDRAM :?: , but it would be fantastic to run MicroPython with more than 1MB of free RAM on 15-20 US$ board :D
Links to documentation for many of those boards can be found in this forum:
http://www.stm32duino.com/viewtopic.php?t=1369
Most interesting:
http://www.dragonwake.com/download/down ... T6_sch.pdf (STM32F407[b]ZET[/b]6 schematic)
https://translate.google.com/translate? ... &sandbox=1
http://loboris.eu/STM32/STM32F407VET6_schematics.jpg (STM32F407[b]VET[/b]6 schematic)
[/quote]
Thank you for the schematics! The STM32F407ZET6 just replace the Arduino DUE and with the STM32F407ZET6 LCD it screams!
Posted: Sun Mar 10, 2019 9:49 am
by uCTRL
Deleted
Sorted out
Posted: Sun Mar 10, 2019 1:49 pm
by mcauser
Renamed to: https://github.com/mcauser/VCC_GND_F407VE
To make room for: https://github.com/mcauser/VCC_GND_F407ZG
GitHub should have added redirects though...
