MCUDev Black STM32F407VET6 + STM32F407ZET6 dev boards
mcauser
Re: MCUDev Black STM32F407VET6 + STM32F407ZET6 dev boards
Post by mcauser » Wed Aug 26, 2020 9:18 am
Perhaps it's time for a new thread.
If you are using I2C with a char lcd, I am assuming you're talking about driving it with a PCF8574 or a MCP23008/MCP23017 backpack.
https://github.com/dhylands/python_lcd has examples using both, and also plain old 4 or 8bit GPIO.
The ESP8266 examples are compatible with the PCF8574, if you change the pins in the I2C() construct, like you have in your example above.
bellad
Post by bellad » Wed Aug 26, 2020 9:27 am
thank
but i not understand
howto install lcd_api and i2c_lcd on the stm32f407vet6 ?
i want use only carracters
bellad
Post by bellad » Wed Aug 26, 2020 9:48 am
oups , sorry , I just came back from holidays :D :D
awlosnie
Post by awlosnie » Tue Dec 29, 2020 10:28 pm
holberg wrote:
Sun Apr 26, 2020 11:14 am
OutoftheBOTS_ wrote:
Fri Apr 24, 2020 8:26 am
holberg wrote:
Thu Apr 23, 2020 9:51 am
I got it running. ILIDriver now in micropython.
But when I want to implement a ILI9341 grafic class, I' run out of RAM. If I check the availabel Memory
MicroPython v1.12-387-g1b1ceb67b on 2020-04-19; MCUDEV STM32F407VE with STM32F407VE
>>> import gc
>>> gc.collect()
>>> gc.mem_free()
33280
its not this much, any Idea ?
Low RAM is the big factor in using this MCU for graphic. The work around is that you have very fast access to the TFT RAM so you need to program in a way that makes use of the TFT RAM and only having super minimal stuff in MCU RAM
Thank you for your reply, I did not use MCU Ram for the TFT. Just some small bytearray for a 5x8 font,
My code (as of my experimental design), working but not yet as class, and yes I'm a "C" Programmer :-)
import stm
from math import trunc
import glcdfont
def FSMC_Init():
    #constants of register
    RCC_AHB3ENR_FSMCEN = 0x1 #bit to enable FSMC clock
    RCC_AHB1ENR_GPIODEN = 0x00000008 #bit to enable D port clock
    RCC_AHB1ENR_GPIOEEN = 0x00000010 #bit to enable E port clock
    FSMC_Bank1_base = 0xA0000000 # 0xA0000000 FSMC registers base address
    FSMC_BCR_bank1_offset = 0x0
    FSMC_BTR_bank1_offset = 0x4
    FSMC_BTR1_ADDSET_0 = 0x00000001
    FSMC_BTR1_ADDSET_1 = 0x00000002
    FSMC_BTR1_ADDSET_2 = 0x00000004
    FSMC_BTR1_ADDSET_3 = 0x00000008
    FSMC_BTR1_ADDSET_T = 0x0000000F			  # ILI9341, this is equivalent to RD high duration, 90ns, we set ADDSET to 15,is 15*6=90ns
    FSMC_BTR1_DATAST   = 0x0000FF00           #<DATAST [3:0] bits (Data-phase duration) */
    FSMC_BTR1_DATAST_0 = 0x00000100
    FSMC_BTR1_DATAST_1 = 0x00000200
    FSMC_BTR1_DATAST_2 = 0x00000400
    FSMC_BTR1_DATAST_3 = 0x00000800
    FSMC_BTR1_DATAST_T = 0x00003C00          # DATAST to 60, which is 60 HCLK cycles, and the time is approximately 360ns.
    FSMC_BTR1_BUSTURN   = 0x000F0000         #<BUSTURN[3:0] bits (Bus turnaround phase duration) */
    FSMC_BTR1_BUSTURN_0 = 0x00010000
    FSMC_BTR1_BUSTURN_1 = 0x00020000
    FSMC_BTR1_BUSTURN_2 = 0x00040000
    FSMC_BTR1_BUSTURN_3 = 0x00080000
    FSMC_BTR1_ACCMOD    = 0x03000000
    #FSMC_BTR1_ADDSET_1 = 0x2
    #FSMC_BTR1_DATAST_1 = 0x00000200
    FSMC_BCR1_MWID_0 = 0x00000010
    FSMC_BCR1_WREN = 0x00001000
    FSMC_BCR1_MBKEN = 0x1
    machine.mem32[stm.RCC + stm.RCC_AHB3ENR] |= RCC_AHB3ENR_FSMCEN
    machine.mem32[stm.RCC + stm.RCC_AHB1ENR] |= RCC_AHB1ENR_GPIODEN | RCC_AHB1ENR_GPIOEEN
    # MODER allows a programmer to define the functionality of a GPIO pin
    # Each pin has2 bitsthat permits the following configurations:
    #  00: Input
    #  01: Output
    #  10: Alternate Function
    #  11: Analog
    # MODER15(1:0)... MODER0(1:0)
    machine.mem32[stm.GPIOD + stm.GPIO_MODER] = 0b10101000001010101000101000101010 #10 10 10 00 00 10 10 10 10 00 10 10 00 10 10 10
    machine.mem32[stm.GPIOE + stm.GPIO_MODER] = 0xAAAA8000
    # OTYPER allows a programmer to configure the output stage of anoutput GPIO pin
    # Each pin has1 bits that permits the following configurations:
    #  0: Push-pull
    #  1: Open Drain
    machine.mem32[stm.GPIOD + stm.GPIO_OSPEEDR] = 0xFFFFFFFF  #0x54154525
    machine.mem32[stm.GPIOE + stm.GPIO_OSPEEDR] = 0xFFFFFFFF  #0x55554000
    machine.mem32[stm.GPIOD + stm.GPIO_AFR0] =  ( (0b1100<<(4*0)) | (0b1100<<(4*1)) | (0b1100<<(4*2)) | (0b1100<<(4*4)) | (0b1100<<(4*5)) | (0b1100<<(4*7)) )
    machine.mem32[stm.GPIOD + stm.GPIO_AFR1] =  ( (0b1100<<(4*(8-8))) | (0b1100<<(4*(9-8))) | (0b1100<<(4*(10-8))) | (0b1100<<(4*(13-8))) | (0b1100<<(4*(14-8))) | (0b1100<<(4*(15-8))))
    machine.mem32[stm.GPIOE + stm.GPIO_AFR0] =  0b1100<<(4*7)
    machine.mem32[stm.GPIOE + stm.GPIO_AFR1] = 0xCCCCCCCC
    FSMC_BTR1_ADDHLD_0  = 0x00000010        #<Bit 0 */
    FSMC_BTR1_CLKDIV_0 = 0x00100000        # <Bit 0 */
    FSMC_BTR1_CLKDIV_1 = 0x00200000        #<Bit 1 */
    FSMC_BCR1_FACCEN = 0x00000040        #<Flash access enable
    machine.mem32[FSMC_Bank1_base + FSMC_BTR_bank1_offset] = FSMC_BTR1_ADDSET_T | FSMC_BTR1_DATAST_T | FSMC_BTR1_ADDHLD_0 # | FSMC_BTR1_CLKDIV_1 | FSMC_BTR1_ACCMOD
    machine.mem32[FSMC_Bank1_base + FSMC_BCR_bank1_offset] = FSMC_BCR1_MWID_0 | FSMC_BCR1_WREN | FSMC_BCR1_MBKEN
def TFT_Init():
    #SOFTWARE RESET
    machine.mem8[LCD_REG] = 0x01
    time.sleep_ms(1000)
    time.sleep_ms(1000)
    #POWER CONTROL A
    machine.mem8[LCD_REG] = 0xCB
    machine.mem8[LCD_RAM] = 0x39
    machine.mem8[LCD_RAM] = 0x2C
    machine.mem8[LCD_RAM] = 0x00
    machine.mem8[LCD_RAM] = 0x34
    machine.mem8[LCD_RAM] = 0x02
    #POWER CONTROL B
    machine.mem8[LCD_REG] = 0xCF
    machine.mem8[LCD_RAM] = 0xC1
    machine.mem8[LCD_RAM] = 0x30
    #DRIVER TIMING CONTROL A
    machine.mem8[LCD_REG] = 0xE8
    machine.mem8[LCD_RAM] = 0x85
    machine.mem8[LCD_RAM] = 0x78
    #DRIVER TIMING CONTROL B
    machine.mem8[LCD_REG] = 0xEA
    #POWER ON SEQUENCE CONTROL
    machine.mem8[LCD_REG] = 0xED
    machine.mem8[LCD_RAM] = 0x64
    machine.mem8[LCD_RAM] = 0x03
    machine.mem8[LCD_RAM] = 0x12
    machine.mem8[LCD_RAM] = 0x81
    #PUMP RATIO CONTROL
    machine.mem8[LCD_REG] = 0xF7
    machine.mem8[LCD_RAM] = 0x20
    #POWER CONTROL,VRH[5:0]
    machine.mem8[LCD_REG] = 0xC0
    machine.mem8[LCD_RAM] = 0x23
    #POWER CONTROL,SAP[2:0]BT[3:0]
    machine.mem8[LCD_REG] = 0xC1
    machine.mem8[LCD_RAM] = 0x10
    #VCM CONTROL
    machine.mem8[LCD_REG] = 0xC5
    machine.mem8[LCD_RAM] = 0x3E
    machine.mem8[LCD_RAM] = 0x28
    #VCM CONTROL 2
    machine.mem8[LCD_REG] = 0xC7
    machine.mem8[LCD_RAM] = 0x86
    #MEMORY ACCESS CONTROL
    machine.mem8[LCD_REG] = 0x36
    machine.mem8[LCD_RAM] = 0x48
    #PIXEL FORMAT 16bit
    machine.mem8[LCD_REG] = 0x3A
    machine.mem8[LCD_RAM] = 0x55
    #FRAME RATIO CONTROL, STANDARD RGB COLOR
    machine.mem8[LCD_REG] = 0xB1
    machine.mem8[LCD_RAM] = 0x18
    #DISPLAY FUNCTION CONTROL
    machine.mem8[LCD_REG] = 0xB6
    machine.mem8[LCD_RAM] = 0x08
    machine.mem8[LCD_RAM] = 0x82
    machine.mem8[LCD_RAM] = 0x27
    #3GAMMA FUNCTION DISABLE
    #machine.mem8[LCD_REG] = 0xF2
    #machine.mem8[LCD_RAM] = 0x00
    #GAMMA CURVE SELECTED
    #machine.mem8[LCD_REG] = 0x26
    #machine.mem8[LCD_RAM] = 0x01
    #POSITIVE GAMMA CORRECTION
    #machine.mem8[LCD_REG] = 0xE0
    #machine.mem8[LCD_RAM] = 0x0F
    #machine.mem8[LCD_RAM] = 0x31
    #machine.mem8[LCD_RAM] = 0x2B
    #machine.mem8[LCD_RAM] = 0x0C
    #machine.mem8[LCD_RAM] = 0x0E
    #machine.mem8[LCD_RAM] = 0x08
    #machine.mem8[LCD_RAM] = 0x4E
    #machine.mem8[LCD_RAM] = 0xF1
    #machine.mem8[LCD_RAM] = 0x37
    #machine.mem8[LCD_RAM] = 0x07
    #machine.mem8[LCD_RAM] = 0x10
    #machine.mem8[LCD_RAM] = 0x03
    #machine.mem8[LCD_RAM] = 0x09
    #NEGATIVE GAMMA CORRECTION
    #machine.mem8[LCD_REG] = 0xE1
    #machine.mem8[LCD_RAM] = 0x14
    #machine.mem8[LCD_RAM] = 0x11
    #machine.mem8[LCD_RAM] = 0xC1
    #machine.mem8[LCD_RAM] = 0x48
    #machine.mem8[LCD_RAM] = 0x36
    #EXIT SLEEP
    machine.mem8[LCD_REG] = 0x11
    time.sleep_ms(1200)
    #TURN ON DISPLAY
    machine.mem8[LCD_REG] = 0x29
    #display inversion
    #machine.mem8[LCD_REG] = 0x21
    #setup Memory Access Control
    machine.mem8[LCD_RAM] = 0b00111111
def ILI9341_Set_Address(X1, Y1, X2, Y2):
    #set X min and max
    machine.mem8[LCD_REG] = 0x2A
    machine.mem16[LCD_RAM] = X1>>8
    machine.mem16[LCD_RAM] = X2>>8
    #set y min and max
    machine.mem8[LCD_REG] = 0x2B
    machine.mem16[LCD_RAM] = Y1>>8
    machine.mem16[LCD_RAM] = Y2>>8
    #write data command
    machine.mem8[LCD_REG] = 0x2C
def drawPixel(X, Y, color):
    ILI9341_Set_Address(X, Y, X, Y)
    machine.mem16[LCD_RAM] = color
def fill(x = 0, y = 0, width = 320, height = 240, color = 0):
    ILI9341_Set_Address(x, y, x + width, x + height)
    for x in range(width):
        for y in range(height):
def _set_ortho_line(width, length, color):
    pixels = width * (length + 1)
    for i in range(pixels):
curWidth  = 240                                                           # Current TFT width
curHeight = 320                                                           # Current TFT height
def drawVline(x, y, length, color, width = 1):
    if length > curHeight: length = curHeight
    if width > 10: width = 10
    ILI9341_Set_Address(x, y, x + (width - 1), y + length - 1)
def drawHline(x, y, length, color, width = 1):
    if length > curWidth: length = curWidth
    ILI9341_Set_Address(x, y, x + length - 1, y + (width - 1))
def drawLine(x, y, x1, y1, color):
    if x == x1:
        drawVline( x, y if y <= y1 else y1, abs(y1 - y), color )
    elif y==y1:
        drawHline( x if x <= x1 else x1, y, abs(x-x1), color )
        # keep positive range for x
        if x1 < x:
            x, x1 = x1, x
            y, y1 = y1, y
        r = (y1 - y) / (x1 - x)
        # select ratio > 1 for fast drawing (and thin line)
        if abs(r) >= 1:
            for i in range(x1 - x + 1):
                drawPixel(x + i, trunc(y + (r * i)), color)
            # keep positive range for y
            if y1 < y:
               x, x1 = x1, x
               y, y1 = y1, y
            # invert the ratio (should be close of r = 1/r)
            r = (x1 - x) / (y1 - y)
            for i in range(y1 - y + 1):
                drawPixel(trunc(x + (r * i)), y + i, color)
def drawRect(x, y, width, height, color, border = 1, infill = None):
    if border is None:
        border = 0
    border = 10 if border > 10 else border
    if width > curWidth:
        width = curWidth
    if height > curHeight:
        height = curHeight
    #height = 2 if height < 2 else height
    #width  = 2 if width  < 2 else width
    #self._graph_orientation()
    if border > 0:
        if border > width // 2:
            border = width // 2 - 1
        X, Y = x, y
        for i in range(2):
            if i == 1:
                Y = y + height - (border - 1)
                Y = y
            drawHline(X, Y, width, color, border)
            print(X, Y, width)
            if border > 1:
                Y = y + 1
                H = height
                Y = y
                H = height + 1
            if i == 1:
                X = x + width - (border - 1)
                X = x
            drawVline(X, Y, H, color, border)
            print(X, Y, H)
        infill = color
    if infill:
        fill(x, y, width, height, infill)
def char(x, y, color):
    cb, l = glcdfont.get_ch('0')
    new = 0
#   rotate pixel by 90 degree
    buf = bytearray(8)
    for j in range(8):
        for i in range(l):
            c = cb[i]   # erste Reihe
            c = c >> j
            if (c & 0x01) == 0x01:
                new |= 1 << i
         #print (hex(new))
        buf[j] = new
        new = 0
 #  print pixel of char
    ILI9341_Set_Address(x, y, x + 5, y + 8)
    for i in range(8):
        c = buf[i]
        for j in range(l):
            #print(j, (c & 0x01))
                machine.mem16[LCD_RAM] = 0
            c = c >> 1
def show_bits(first, second, len = 8):
    out =""
    for i in range(len):
        f = (first << i) & 0x80
        #print(hex(f))
        if f:
            out = out + "1"
            out = out + "0"
        f = (second << i) & 0x80
        if f:
            out = out + "1"
            out = out + "0"
    print (out)
def big_char(x, y, char, fgcolor=0xffff, bgcolor=0):
    k = 0
    cb, l = glcdfont.get_ch(char)
    pix = bytearray(24)
    for i in range(6):
    # first Byte
        a = cb[i]
        pix[k] = 0
        if (a&0x10): pix[k]|=0x03
        if (a&0x20): pix[k]|=0x0c
        if (a&0x40): pix[k]|=0x30
        if (a&0x80): pix[k]|=0xc0
        k += 1
        pix[k] = 0
        if (a&0x01): pix[k]|=0x03		# die vier doppelten punkte setzen
        if (a&0x02): pix[k]|=0x0c
        if (a&0x04): pix[k]|=0x30
        if (a&0x08): pix[k]|=0xc0
        k += 1
        pix[k] = 0
        k += 1
        pix[k] = 0
        k += 1
    new = 0
    buf = bytearray(32)
    for j in range(8):
        for i in range(8):
            c = pix[(i * 2) + 1] # (High) Low
            c = c >> j
                new |= 0x80 >> i
        buf[(j * 2)] = new
        new = 0
        for i in range(4):
            c = pix[(i * 2) + 17] # zweite Reihe
            c = c >> j
                new |= 0x80 >> i
        buf[(j * 2)+1] = new
        #show_bits(buf[j*2], buf[(j*2)+1])
        new = 0
    for j in range(8):
        for i in range(8):
            c = pix[i * 2] # erste Reihe
            c = c >> j
                new |= 0x80 >> i
        buf[(j * 2) + 16] = new
        new = 0
        for i in range(4):
            c = pix[(i * 2) + 16] # zweite Reihe
            c = c >> j
                new |= 0x80 >> i
        buf[(j * 2) + 17] = new
        new = 0
        #show_bits(buf[(j*2) + 16], buf[(j*2)+17])
    ILI9341_Set_Address(x, y, x + 11, y + 15)
    for i in range(16):
        #show_bits(buf[i*2], buf[(i*2)+1])
        c = buf[i * 2]
        for j in range(8):
            if (c & 0x80) == 0x80:
                machine.mem16[LCD_RAM] = fgcolor
                machine.mem16[LCD_RAM] = bgcolor
            c = c << 1
        c = buf[(i * 2) + 1]
        for j in range(4):
            c = c << 1
def string_big(x, y, string, fgcolor=0xffff, bgcolor=0):
    for i in range(len(string)):
        big_char(x + (i*11), y, string[i], fgcolor, bgcolor)
LCD_REG = const(0x60000002)
LCD_RAM = const(0x60080002)
This is the code that I was looking for, but still low performance in drawing. Couldn't wait for the final python script, so created following repository with some customizations (This forum is full of information required to prepare the pimped python script - nice!).
https://github.com/awlosnie/micropython-fsmc-ili9341
Also added a short video demonstrating the speed of drawing primitives
https://streamable.com/gu54zt
VASIL
Post by VASIL » Sun Apr 04, 2021 4:26 pm
Hi, I am also new to micropython. I have a Black STM32F407VET6 board. I have installed micropython on this MicroPython board v1.14 on 2021-04-04. I was able to connect the onboard SPI flash. But I cannot connect the SD card. I have a question whether onboard SPI flash and SD card should exist at the same time. Can someone please provide a sample working mpconfigboard.h code for BLACK_F407VE. Thanks
DJShadow1966
Post by DJShadow1966 » Mon Apr 05, 2021 7:08 am
Hello
The SD card has to inserted when you power on the board, you will not be able to change the card when the board is powered on. Have you followed the instruction on an earlier post to enable the SD card, as it isnt enabled by default.
viewtopic.php?f=12&t=3086&p=38142&hilit=sd+card#p38142
Regards Mike
VASIL
Post by VASIL » Mon Apr 05, 2021 1:36 pm
Hi
SD card is inserted when the board is turned on. I have instructions in the previous post
[url][url]https://forum.micropython.org ... 6&start=90[/url]st[/url]
#define MICROPY_HW_HAS_SWITCH (1) // has 2 buttons KEY0=PE4, KEY1=PE3
#define MICROPY_HW_HAS_FLASH (1)
#define MICROPY_HW_ENABLE_RNG (1)
#define MICROPY_HW_ENABLE_RTC (1)
#define MICROPY_HW_ENABLE_DAC (1)
#define MICROPY_HW_ENABLE_USB (1)
#define MICROPY_HW_ENABLE_SDCARD (1) // it has a sd scard, but no detect pin
#define MICROPY_HW_SDCARD_MOUNT_AT_BOOT (1)
I also edited the ports / stm32 / sdcard.c file to follow JohnLittle's guidelines. And still But I can't connect the SD card.
Аfter soft reset I have
MPY: sync filesystems
MPY: soft reboot
MPY: can't mount SD card
MicroPython v1.14 on 2021-04-05; MCUDEV STM32F407VE with STM32F407VE
Type "help ()" for more information.
VASIL
Post by VASIL » Mon Apr 05, 2021 3:54 pm
Hi
Sorry for the inconvenience. The reason was in a bad SD card. After replacement, everything works.
