Perhaps it's time for a new thread.
If you are using I2C with a char lcd, I am assuming you're talking about driving it with a PCF8574 or a MCP23008/MCP23017 backpack.
https://github.com/dhylands/python_lcd has examples using both, and also plain old 4 or 8bit GPIO.
The ESP8266 examples are compatible with the PCF8574, if you change the pins in the I2C() construct, like you have in your example above.
MCUDev Black STM32F407VET6 + STM32F407ZET6 dev boards
Re: MCUDev Black STM32F407VET6 + STM32F407ZET6 dev boards
thank
but i not understand
howto install lcd_api and i2c_lcd on the stm32f407vet6 ?
i want use only carracters
oups , sorry , I just came back from holidays
This is the code that I was looking for, but still low performance in drawing. Couldn't wait for the final python script, so created following repository with some customizations (This forum is full of information required to prepare the pimped python script - nice!).holberg wrote: ↑Sun Apr 26, 2020 11:14 amThank you for your reply, I did not use MCU Ram for the TFT. Just some small bytearray for a 5x8 font,OutoftheBOTS_ wrote: ↑Fri Apr 24, 2020 8:26 amLow RAM is the big factor in using this MCU for graphic. The work around is that you have very fast access to the TFT RAM so you need to program in a way that makes use of the TFT RAM and only having super minimal stuff in MCU RAMholberg wrote: ↑Thu Apr 23, 2020 9:51 am
I got it running. ILIDriver now in micropython.
But when I want to implement a ILI9341 grafic class, I' run out of RAM. If I check the availabel Memory
MicroPython v1.12-387-g1b1ceb67b on 2020-04-19; MCUDEV STM32F407VE with STM32F407VE
>>> import gc
>>> gc.collect()
>>> gc.mem_free()
33280
its not this much, any Idea ?
My code (as of my experimental design), working but not yet as class, and yes I'm a "C" Programmer
import stm import time import machine from math import trunc import glcdfont def FSMC_Init(): #constants of register RCC_AHB3ENR_FSMCEN = 0x1 #bit to enable FSMC clock RCC_AHB1ENR_GPIODEN = 0x00000008 #bit to enable D port clock RCC_AHB1ENR_GPIOEEN = 0x00000010 #bit to enable E port clock FSMC_Bank1_base = 0xA0000000 # 0xA0000000 FSMC registers base address FSMC_BCR_bank1_offset = 0x0 FSMC_BTR_bank1_offset = 0x4 FSMC_BTR1_ADDSET_0 = 0x00000001 FSMC_BTR1_ADDSET_1 = 0x00000002 FSMC_BTR1_ADDSET_2 = 0x00000004 FSMC_BTR1_ADDSET_3 = 0x00000008 FSMC_BTR1_ADDSET_T = 0x0000000F # ILI9341, this is equivalent to RD high duration, 90ns, we set ADDSET to 15,is 15*6=90ns FSMC_BTR1_DATAST = 0x0000FF00 #<DATAST [3:0] bits (Data-phase duration) */ FSMC_BTR1_DATAST_0 = 0x00000100 FSMC_BTR1_DATAST_1 = 0x00000200 FSMC_BTR1_DATAST_2 = 0x00000400 FSMC_BTR1_DATAST_3 = 0x00000800 FSMC_BTR1_DATAST_T = 0x00003C00 # DATAST to 60, which is 60 HCLK cycles, and the time is approximately 360ns. FSMC_BTR1_BUSTURN = 0x000F0000 #<BUSTURN[3:0] bits (Bus turnaround phase duration) */ FSMC_BTR1_BUSTURN_0 = 0x00010000 FSMC_BTR1_BUSTURN_1 = 0x00020000 FSMC_BTR1_BUSTURN_2 = 0x00040000 FSMC_BTR1_BUSTURN_3 = 0x00080000 FSMC_BTR1_ACCMOD = 0x03000000 #FSMC_BTR1_ADDSET_1 = 0x2 #FSMC_BTR1_DATAST_1 = 0x00000200 FSMC_BCR1_MWID_0 = 0x00000010 FSMC_BCR1_WREN = 0x00001000 FSMC_BCR1_MBKEN = 0x1 machine.mem32[stm.RCC + stm.RCC_AHB3ENR] |= RCC_AHB3ENR_FSMCEN machine.mem32[stm.RCC + stm.RCC_AHB1ENR] |= RCC_AHB1ENR_GPIODEN | RCC_AHB1ENR_GPIOEEN # MODER allows a programmer to define the functionality of a GPIO pin # Each pin has2 bitsthat permits the following configurations: # 00: Input # 01: Output # 10: Alternate Function # 11: Analog # MODER15(1:0)... MODER0(1:0) machine.mem32[stm.GPIOD + stm.GPIO_MODER] = 0b10101000001010101000101000101010 #10 10 10 00 00 10 10 10 10 00 10 10 00 10 10 10 machine.mem32[stm.GPIOE + stm.GPIO_MODER] = 0xAAAA8000 # OTYPER allows a programmer to configure the output stage of anoutput GPIO pin # Each pin has1 bits that permits the following configurations: # 0: Push-pull # 1: Open Drain machine.mem32[stm.GPIOD + stm.GPIO_OSPEEDR] = 0xFFFFFFFF #0x54154525 machine.mem32[stm.GPIOE + stm.GPIO_OSPEEDR] = 0xFFFFFFFF #0x55554000 machine.mem32[stm.GPIOD + stm.GPIO_AFR0] = ( (0b1100<<(4*0)) | (0b1100<<(4*1)) | (0b1100<<(4*2)) | (0b1100<<(4*4)) | (0b1100<<(4*5)) | (0b1100<<(4*7)) ) machine.mem32[stm.GPIOD + stm.GPIO_AFR1] = ( (0b1100<<(4*(8-8))) | (0b1100<<(4*(9-8))) | (0b1100<<(4*(10-8))) | (0b1100<<(4*(13-8))) | (0b1100<<(4*(14-8))) | (0b1100<<(4*(15-8)))) machine.mem32[stm.GPIOE + stm.GPIO_AFR0] = 0b1100<<(4*7) machine.mem32[stm.GPIOE + stm.GPIO_AFR1] = 0xCCCCCCCC FSMC_BTR1_ADDHLD_0 = 0x00000010 #<Bit 0 */ FSMC_BTR1_CLKDIV_0 = 0x00100000 # <Bit 0 */ FSMC_BTR1_CLKDIV_1 = 0x00200000 #<Bit 1 */ FSMC_BCR1_FACCEN = 0x00000040 #<Flash access enable machine.mem32[FSMC_Bank1_base + FSMC_BTR_bank1_offset] = FSMC_BTR1_ADDSET_T | FSMC_BTR1_DATAST_T | FSMC_BTR1_ADDHLD_0 # | FSMC_BTR1_CLKDIV_1 | FSMC_BTR1_ACCMOD machine.mem32[FSMC_Bank1_base + FSMC_BCR_bank1_offset] = FSMC_BCR1_MWID_0 | FSMC_BCR1_WREN | FSMC_BCR1_MBKEN def TFT_Init(): #SOFTWARE RESET machine.mem8[LCD_REG] = 0x01 time.sleep_ms(1000) machine.mem8[LCD_REG] = 0x01 time.sleep_ms(1000) #POWER CONTROL A machine.mem8[LCD_REG] = 0xCB machine.mem8[LCD_RAM] = 0x39 machine.mem8[LCD_RAM] = 0x2C machine.mem8[LCD_RAM] = 0x00 machine.mem8[LCD_RAM] = 0x34 machine.mem8[LCD_RAM] = 0x02 #POWER CONTROL B machine.mem8[LCD_REG] = 0xCF machine.mem8[LCD_RAM] = 0x00 machine.mem8[LCD_RAM] = 0xC1 machine.mem8[LCD_RAM] = 0x30 #DRIVER TIMING CONTROL A machine.mem8[LCD_REG] = 0xE8 machine.mem8[LCD_RAM] = 0x85 machine.mem8[LCD_RAM] = 0x00 machine.mem8[LCD_RAM] = 0x78 #DRIVER TIMING CONTROL B machine.mem8[LCD_REG] = 0xEA machine.mem8[LCD_RAM] = 0x00 machine.mem8[LCD_RAM] = 0x00 #POWER ON SEQUENCE CONTROL machine.mem8[LCD_REG] = 0xED machine.mem8[LCD_RAM] = 0x64 machine.mem8[LCD_RAM] = 0x03 machine.mem8[LCD_RAM] = 0x12 machine.mem8[LCD_RAM] = 0x81 #PUMP RATIO CONTROL machine.mem8[LCD_REG] = 0xF7 machine.mem8[LCD_RAM] = 0x20 #POWER CONTROL,VRH[5:0] machine.mem8[LCD_REG] = 0xC0 machine.mem8[LCD_RAM] = 0x23 #POWER CONTROL,SAP[2:0]BT[3:0] machine.mem8[LCD_REG] = 0xC1 machine.mem8[LCD_RAM] = 0x10 #VCM CONTROL machine.mem8[LCD_REG] = 0xC5 machine.mem8[LCD_RAM] = 0x3E machine.mem8[LCD_RAM] = 0x28 #VCM CONTROL 2 machine.mem8[LCD_REG] = 0xC7 machine.mem8[LCD_RAM] = 0x86 #MEMORY ACCESS CONTROL machine.mem8[LCD_REG] = 0x36 machine.mem8[LCD_RAM] = 0x48 #PIXEL FORMAT 16bit machine.mem8[LCD_REG] = 0x3A machine.mem8[LCD_RAM] = 0x55 #FRAME RATIO CONTROL, STANDARD RGB COLOR machine.mem8[LCD_REG] = 0xB1 machine.mem8[LCD_RAM] = 0x00 machine.mem8[LCD_RAM] = 0x18 #DISPLAY FUNCTION CONTROL machine.mem8[LCD_REG] = 0xB6 machine.mem8[LCD_RAM] = 0x08 machine.mem8[LCD_RAM] = 0x82 machine.mem8[LCD_RAM] = 0x27 #3GAMMA FUNCTION DISABLE #machine.mem8[LCD_REG] = 0xF2 #machine.mem8[LCD_RAM] = 0x00 #GAMMA CURVE SELECTED #machine.mem8[LCD_REG] = 0x26 #machine.mem8[LCD_RAM] = 0x01 #POSITIVE GAMMA CORRECTION #machine.mem8[LCD_REG] = 0xE0 #machine.mem8[LCD_RAM] = 0x0F #machine.mem8[LCD_RAM] = 0x31 #machine.mem8[LCD_RAM] = 0x2B #machine.mem8[LCD_RAM] = 0x0C #machine.mem8[LCD_RAM] = 0x0E #machine.mem8[LCD_RAM] = 0x08 #machine.mem8[LCD_RAM] = 0x4E #machine.mem8[LCD_RAM] = 0xF1 #machine.mem8[LCD_RAM] = 0x37 #machine.mem8[LCD_RAM] = 0x07 #machine.mem8[LCD_RAM] = 0x10 #machine.mem8[LCD_RAM] = 0x03 #machine.mem8[LCD_RAM] = 0x0E #machine.mem8[LCD_RAM] = 0x09 #machine.mem8[LCD_RAM] = 0x00 #NEGATIVE GAMMA CORRECTION #machine.mem8[LCD_REG] = 0xE1 #machine.mem8[LCD_RAM] = 0x00 #machine.mem8[LCD_RAM] = 0x0E #machine.mem8[LCD_RAM] = 0x14 #machine.mem8[LCD_RAM] = 0x03 #machine.mem8[LCD_RAM] = 0x11 #machine.mem8[LCD_RAM] = 0x07 #machine.mem8[LCD_RAM] = 0x31 #machine.mem8[LCD_RAM] = 0xC1 #machine.mem8[LCD_RAM] = 0x48 #machine.mem8[LCD_RAM] = 0x08 #machine.mem8[LCD_RAM] = 0x0F #machine.mem8[LCD_RAM] = 0x0C #machine.mem8[LCD_RAM] = 0x31 #machine.mem8[LCD_RAM] = 0x36 #machine.mem8[LCD_RAM] = 0x0F #EXIT SLEEP machine.mem8[LCD_REG] = 0x11 time.sleep_ms(1200) #TURN ON DISPLAY machine.mem8[LCD_REG] = 0x29 #display inversion #machine.mem8[LCD_REG] = 0x21 #setup Memory Access Control machine.mem8[LCD_REG] = 0x36 machine.mem8[LCD_RAM] = 0b00111111 def ILI9341_Set_Address(X1, Y1, X2, Y2): #set X min and max machine.mem8[LCD_REG] = 0x2A machine.mem16[LCD_RAM] = X1>>8 machine.mem16[LCD_RAM] = X1 machine.mem16[LCD_RAM] = X2>>8 machine.mem16[LCD_RAM] = X2 #set y min and max machine.mem8[LCD_REG] = 0x2B machine.mem16[LCD_RAM] = Y1>>8 machine.mem16[LCD_RAM] = Y1 machine.mem16[LCD_RAM] = Y2>>8 machine.mem16[LCD_RAM] = Y2 #write data command machine.mem8[LCD_REG] = 0x2C def drawPixel(X, Y, color): ILI9341_Set_Address(X, Y, X, Y) machine.mem16[LCD_RAM] = color def fill(x = 0, y = 0, width = 320, height = 240, color = 0): ILI9341_Set_Address(x, y, x + width, x + height) for x in range(width): for y in range(height): machine.mem16[LCD_RAM] = color def _set_ortho_line(width, length, color): pixels = width * (length + 1) for i in range(pixels): machine.mem16[LCD_RAM] = color curWidth = 240 # Current TFT width curHeight = 320 # Current TFT height def drawVline(x, y, length, color, width = 1): if length > curHeight: length = curHeight if width > 10: width = 10 ILI9341_Set_Address(x, y, x + (width - 1), y + length - 1) _set_ortho_line(width, length, color) def drawHline(x, y, length, color, width = 1): if length > curWidth: length = curWidth if width > 10: width = 10 ILI9341_Set_Address(x, y, x + length - 1, y + (width - 1)) _set_ortho_line(width, length, color) def drawLine(x, y, x1, y1, color): if x == x1: drawVline( x, y if y <= y1 else y1, abs(y1 - y), color ) elif y==y1: drawHline( x if x <= x1 else x1, y, abs(x-x1), color ) else: # keep positive range for x if x1 < x: x, x1 = x1, x y, y1 = y1, y r = (y1 - y) / (x1 - x) # select ratio > 1 for fast drawing (and thin line) if abs(r) >= 1: for i in range(x1 - x + 1): drawPixel(x + i, trunc(y + (r * i)), color) else: # keep positive range for y if y1 < y: x, x1 = x1, x y, y1 = y1, y # invert the ratio (should be close of r = 1/r) r = (x1 - x) / (y1 - y) for i in range(y1 - y + 1): drawPixel(trunc(x + (r * i)), y + i, color) def drawRect(x, y, width, height, color, border = 1, infill = None): if border is None: border = 0 border = 10 if border > 10 else border if width > curWidth: width = curWidth if height > curHeight: height = curHeight #height = 2 if height < 2 else height #width = 2 if width < 2 else width #self._graph_orientation() if border > 0: if border > width // 2: border = width // 2 - 1 X, Y = x, y for i in range(2): if i == 1: Y = y + height - (border - 1) else: Y = y drawHline(X, Y, width, color, border) print(X, Y, width) if border > 1: Y = y + 1 H = height else: Y = y H = height + 1 if i == 1: X = x + width - (border - 1) else: X = x drawVline(X, Y, H, color, border) print(X, Y, H) else: infill = color if infill: fill(x, y, width, height, infill) def char(x, y, color): cb, l = glcdfont.get_ch('0') new = 0 # rotate pixel by 90 degree buf = bytearray(8) for j in range(8): for i in range(l): c = cb[i] # erste Reihe c = c >> j if (c & 0x01) == 0x01: new |= 1 << i #print (hex(new)) buf[j] = new new = 0 # print pixel of char ILI9341_Set_Address(x, y, x + 5, y + 8) for i in range(8): c = buf[i] for j in range(l): #print(j, (c & 0x01)) if (c & 0x01) == 0x01: machine.mem16[LCD_RAM] = color else: machine.mem16[LCD_RAM] = 0 c = c >> 1 def show_bits(first, second, len = 8): out ="" for i in range(len): f = (first << i) & 0x80 #print(hex(f)) if f: out = out + "1" else: out = out + "0" for i in range(len): f = (second << i) & 0x80 if f: out = out + "1" else: out = out + "0" print (out) def big_char(x, y, char, fgcolor=0xffff, bgcolor=0): k = 0 cb, l = glcdfont.get_ch(char) pix = bytearray(24) for i in range(6): # first Byte a = cb[i] pix[k] = 0 if (a&0x10): pix[k]|=0x03 if (a&0x20): pix[k]|=0x0c if (a&0x40): pix[k]|=0x30 if (a&0x80): pix[k]|=0xc0 k += 1 pix[k] = 0 if (a&0x01): pix[k]|=0x03 # die vier doppelten punkte setzen if (a&0x02): pix[k]|=0x0c if (a&0x04): pix[k]|=0x30 if (a&0x08): pix[k]|=0xc0 k += 1 pix[k] = 0 if (a&0x10): pix[k]|=0x03 if (a&0x20): pix[k]|=0x0c if (a&0x40): pix[k]|=0x30 if (a&0x80): pix[k]|=0xc0 k += 1 pix[k] = 0 if (a&0x01): pix[k]|=0x03 # die vier doppelten punkte setzen if (a&0x02): pix[k]|=0x0c if (a&0x04): pix[k]|=0x30 if (a&0x08): pix[k]|=0xc0 k += 1 new = 0 # rotate pixel by 90 degree buf = bytearray(32) for j in range(8): for i in range(8): c = pix[(i * 2) + 1] # (High) Low c = c >> j if (c & 0x01) == 0x01: new |= 0x80 >> i buf[(j * 2)] = new new = 0 for i in range(4): c = pix[(i * 2) + 17] # zweite Reihe c = c >> j if (c & 0x01) == 0x01: new |= 0x80 >> i buf[(j * 2)+1] = new #show_bits(buf[j*2], buf[(j*2)+1]) new = 0 for j in range(8): for i in range(8): c = pix[i * 2] # erste Reihe c = c >> j if (c & 0x01) == 0x01: new |= 0x80 >> i buf[(j * 2) + 16] = new new = 0 for i in range(4): c = pix[(i * 2) + 16] # zweite Reihe c = c >> j if (c & 0x01) == 0x01: new |= 0x80 >> i buf[(j * 2) + 17] = new new = 0 #show_bits(buf[(j*2) + 16], buf[(j*2)+17]) # print pixel of char ILI9341_Set_Address(x, y, x + 11, y + 15) for i in range(16): #show_bits(buf[i*2], buf[(i*2)+1]) c = buf[i * 2] for j in range(8): if (c & 0x80) == 0x80: machine.mem16[LCD_RAM] = fgcolor else: machine.mem16[LCD_RAM] = bgcolor c = c << 1 c = buf[(i * 2) + 1] for j in range(4): if (c & 0x80) == 0x80: machine.mem16[LCD_RAM] = fgcolor else: machine.mem16[LCD_RAM] = bgcolor c = c << 1 def string_big(x, y, string, fgcolor=0xffff, bgcolor=0): for i in range(len(string)): big_char(x + (i*11), y, string[i], fgcolor, bgcolor) LCD_REG = const(0x60000002) LCD_RAM = const(0x60080002)
https://github.com/awlosnie/micropython-fsmc-ili9341
Also added a short video demonstrating the speed of drawing primitives
https://streamable.com/gu54zt
